liberlois 0 Report post Posted October 29, 2007 nizoral is not working on me.... anyone here wanna recommend what do i do with my hair i mean what do i apply? Share this post Link to post Share on other sites
Picc84 0 Report post Posted October 29, 2007 I've had this problem for awhile. I have medicated shamopp as well and it did not work for me. I find combing my hair out allot for 10 minutes THAN useing the Selson Blue really helps. It gets the dandruff in there out, and keeps it out. Share this post Link to post Share on other sites
cchsinteract 0 Report post Posted January 5, 2008 I put mayo in my hair, it works great! But don't wash your hair everyday, maybe like 3 times a week. Share this post Link to post Share on other sites
Evolke 0 Report post Posted January 16, 2008 Well, I got dandruff once .. then I started using Head and Shoulders which totaly cleared it up .. mind you it wasnt serious ... Share this post Link to post Share on other sites
strange-garden 0 Report post Posted January 16, 2008 (edited) Ok...First things first...It might not be dandruff.Could be an allergic reaction to chemicals. Could be that you leave it in for too long causing and allergic reaction and leavig you with a dry scalp. How often do you wash your hair?-edit-I have only had 'dandruff' once and I have really sensitive skin to chemicals...I went to an all natural shop to get this shampoo that smealt really nice...Funny thing they said it was all natural, yet it left me with the itchiest scalp ever. It went away in a few days, cause i went back to my normal shampoo...It sucks though because the shampoo was heaps expensive. Edited January 16, 2008 by strange-garden (see edit history) Share this post Link to post Share on other sites
myfujiang 0 Report post Posted January 19, 2008 It's really problem,I'm affliction too. Share this post Link to post Share on other sites
demank 0 Report post Posted February 8, 2008 dandruff problem, every men have this problem usually.i think you may not use hard shampoo.just use the soft one., Share this post Link to post Share on other sites
organized 0 Report post Posted February 12, 2008 Have you guys heard of the shampoo RESDAN. It works for me but I had to stop using is because it's quite expensive. Head 'n Shoulders doesnt work for me, unless I use it every single day. It works just as well as baby shampoo... :-)Hope mankind will oneday find a cure for this terrible, annoying... thingie.I would even sacrefice my moustage for it Mike Share this post Link to post Share on other sites
iGuest 3 Report post Posted April 4, 2008 Dandruff Dandruff Problem  Replying to downsy007 Replying to techclave  Have you gone to the doctor in regards to your problem? It might be psoriasis instead of just a dandruff problem. Shampoos only alleviate the problem but doesn't fix it, and creams or psoriasin helps the itch but again to no avail. Changing your diet by eliminating sugars and alcohol is more effective.  -reply by Rose Share this post Link to post Share on other sites
Wetton 0 Report post Posted April 27, 2008 I used to have the same problem. I asked the doctor, and he reccomended a few things.1)Wash your hair in COLD WATER. Hot water just makes the scalp drier.2)When shampooing, make sure you wash it out thoroughly, often dandruff is just shampoo that you didn't wash out properly.It worked for me, hope it helps.Thanks. Share this post Link to post Share on other sites
daveodagreatbeast19 0 Report post Posted May 9, 2008 yo i have dandruff and the shampoos dont really work i tryed head and shoulders but that only works when it wants to. i tried selsun and it work when i used it but it kept getting in my eyes. so what i suggest is try the vinager thing out i am this weekend. And as for oils my sister in law put a oil in my head called "Dr. Hobbs" I think she got it from a convience store. but if you can find it massge it into your hair an hour after you wash you hair. Also the mayo thing worked for my aunt. She let it set in her hair for about an hour. Just try one of my techniques. see u later Share this post Link to post Share on other sites
mailtojumper 0 Report post Posted May 21, 2008 i hate dandruff as it is very flakes and when u brush your hands over your here it goes all white even talking about it is making me itchI had this dandruff problem quite much some time back. some one suggested me that lime juice is a good cure for this. Cut the lemon in to two halfs and rub them on the hair. This will reduce the dandruff to a large extent. Share this post Link to post Share on other sites
mailtojumper 0 Report post Posted May 21, 2008 Here are some of tips for hair prevention and dandruff... Take about 2 cups of henna (the quantity actually depends on the length of your hair) and mix with it 4 teaspoons each of lemon juice and coffee, 2 raw eggs and tea-water or amla water. Tea water can be made by boiling used tea leaves again, cooling the water and straining it. The water may be mixed with the rest of the henna ingredients. Amla water is made by soaking dry amla overnight in 2 cups of water overnight. Next day, strain the water and keep it. Grind the soaked amla. Mix the amla with the henna and use the water to mix the henna and other ingredients into a thick paste. Amla is said to check greying. Notice from rvalkass: Anything you copy must be put in Quote tags. Share this post Link to post Share on other sites
radames 0 Report post Posted September 9, 2008 See a dermatologist and they will examine your scalp. Check if it caused by allergy or you are stress. Share this post Link to post Share on other sites
Deretto 0 Report post Posted September 10, 2008 Yeah, don't use hot water. Also, if you use conditioner, don't rub it into your scalp. That seems to do the trick. Share this post Link to post Share on other sites
