tinoymalayil 0 Report post Posted August 1, 2009 Hui friends ..there are two types of method get() method and post() method using in JSP to send data ..post() method send the data in header of the body and get method sends through the address bar..what is the advantage of post() method ..please reply. Share this post Link to post Share on other sites
jlhaslip 4 Report post Posted August 1, 2009 The biggest advantage would be that POST action would be more secure as a method since the data being sent is not visible in the URL.Using the GET method adds the data to the visible portion of the URL and is "less secure".When send ing sensitive information, or data which could be used to log-in to a site as an example, use the POST method. GET is often used to direct the client to specific pages on a dynamic site. For example, this page can be found using the GET method and the Query String is everything following the last '/' in the URLie: http://forums.xisto.com/topic/67555-difference-between-get-and-post-method-to-set-the-data/ Share this post Link to post Share on other sites
delivi 0 Report post Posted August 2, 2009 The GET method should be used for retrieving information from the server and should not be used for any changes to be made at the server-side.The POST method is more secure and should be used for actions that'll make changes at the server-side.In the POST method, the data is included as a part of the message body; whereas in the GET, the data is passed in the url as query string.The maximum length of the URL that is supported by Internet Explorer is 2083, so you cannot send huge amount of data using the GET method, whereas you've no limits using the POST method. Share this post Link to post Share on other sites
webishqiptar 0 Report post Posted August 2, 2009 Well. to answer shortly and I am sure you can understand by yourself too,if you try to think harder. So if you use post(), this means data and information cannot be seen. So you can send a password using post(), while using get() your password would be visible. Share this post Link to post Share on other sites
kleong 0 Report post Posted August 5, 2009 You would not want the chunk of data entered in the form to be displayed or embedded in the url ya? For get(), I would personally used it if it is to send none "personal" information, like sending of page etc. Anything else, I will use post(). Share this post Link to post Share on other sites
iGuest 3 Report post Posted March 12, 2010 With get request we can send data of 2048 characters. And there is no limit with post request. Get data is appended at the end of url. It is visible to everybody. Post data is sent in body of request header. And it is secure to send password in post request.-reply by avinash Share this post Link to post Share on other sites
