Unregistered 012 0 Report post Posted February 13, 2007 I was hosted here before, but then so many things were going wrong with my site. i could never get the skin uploaded and simple problems like that. so i deleted my hosting account, so i could restart. But before i do this i need to learn how to do all HTML and other programs like that. so it is a lot easier for me to run my site. So if anybody here has some really good tutorials and teaching programs for HTML, and web page design, please post them here. thanks. Share this post Link to post Share on other sites
jlhaslip 4 Report post Posted February 13, 2007 Start over at the http://www.w3schools.com/ site. They have a nice set of tutorials for beginners and can assist you with html and css, both.They also have a Reference section and a pretty cool 'try-it' editor which assists you in refining your code and testing stuff. Share this post Link to post Share on other sites
garbage 0 Report post Posted February 13, 2007 Start over at the http://www.w3schools.com/ site. They have a nice set of tutorials for beginners and can assist you with html and css, both. They also have a Reference section and a pretty cool 'try-it' editor which assists you in refining your code and testing stuff. he has suggested the best place to go and leanr.. so id be there for the next few weeks just reading. Share this post Link to post Share on other sites
matak 2 Report post Posted February 13, 2007 and when learning HTML, use your notepad, and type slowly that code you are learning. save it and test it. the more you type code, the faster you will learn it.w3schools is all you need, and you can check out this site toohttp://www.htmldog.com/ Share this post Link to post Share on other sites
Forbez 0 Report post Posted February 13, 2007 W3 is the best place to learn. Learn HTML before you start on anything else. HTML is the simplest and will help you understand the harder stuff more. Share this post Link to post Share on other sites
Unregistered 012 0 Report post Posted February 13, 2007 Thanks guys. This will really help me out. Im gonna start reading as much of it as i can. Once again thanks. Share this post Link to post Share on other sites
Hadi 0 Report post Posted February 14, 2007 savagemonkeyz14, W3 schools is one of the hardest place to learn, even if it was html, or any other launguage, so just if you are looking for a nice and quick website, then get a blog like word press, or if you want a quick template there are a lot on google, if you didn't find one for your taste I'll be happy to make one, no charge, pointing that I have all necessary software an knowledge: Photoshop, Dreamweaver, flash... Share this post Link to post Share on other sites
Plenoptic 0 Report post Posted February 15, 2007 Personally, I learned from http://www.yourhtmlsource.com/ It was pretty simple for me to get going. They have a specific tutorial for your first web site. It worked for me but it really depends on what you are trying to do. http://www.pixel2life.com/ is good if you have something specific in mind. You can search on a tutorial to do certain things. That is for more than just HTML. http://www.w3schools.com/ isn't that bad either. I haven't really tried to use them that much but they have a lot of information on there. Whichever really works best for you but there are some good sources to get you going. Just takes a bit of practice and learn as you go. That is basically how I learned. Share this post Link to post Share on other sites
zyzzyvette 0 Report post Posted February 15, 2007 savagemonkeyz14, W3 schools is one of the hardest place to learn, even if it was html, or any other launguageI agree, unless you learn best by reading, or can read long, sometimes complex, stretches of text and comprehend it 100%, its probably not the best place to start out. Its a good site in that it won't teach you how do to anything improperly (since they make the standards and all), and is a solid reference if you just need to look something up, but I wouldn't use it if I were just starting out. Tizag is my favorite place for these sorts of tutorials, but I haven't looked at some of the other sites already mentioned, so they may be better. Share this post Link to post Share on other sites
cwconline 0 Report post Posted February 25, 2007 Not true... W3 gives you a do it your self type of code base when your learning HTML... they show you what it looks like outputted and then when you add code your self or change something you an see what you did...I learned a lot from w3 schools. Share this post Link to post Share on other sites
sandrapanther 0 Report post Posted March 13, 2007 Actually I don,t have that direct answer to your problem .But I still want to add that when I faces the similar obstacle then I visited the site of http://www.webdesigningcompany.net/ -recommended by some of my friends.They cure it by providing the appropriate remedy. Share this post Link to post Share on other sites
vondominion 0 Report post Posted June 3, 2007 i learned php, html, and sql form w3schools. as they have all said before, it is the best place to learn it. Share this post Link to post Share on other sites
