Waleed Dar
How To Bypass Websense? other than using proxy...
I have the answer...
http://www.gardennetworks.org/download
Download this program, put it on your flash drive or save it to your home directory. No instal needed, just run the .Exe file. It tunnels your traffic through normal https packets. Unless your work/school has a secondary wall that examines each packet then it will get you through. ;)
Works for me always.
Good luck guys.
-reply by jwr5184
vtunnel
Replying to Feedbacker
Yes http://forums.xisto.com/no_longer_exists/ is good but you get this annoying scrip issue going on that wont let you click on anything now if you use http://forums.xisto.com/no_longer_exists/ you can turn off the scrip and click on buttons ^.^
-reply by random bored guy
On your home computer go to https://secure.logmein.com/home sign up for the free version of the account or if you feel like, get the pro version. Make sure the software is running on your computer and then go to https://secure.logmein.com/home at work or school or wherever your websensed network is and log in with your email and password. Use your computer to go to websites you can't go to websense free. Best part is that logmein is browser based so unless your work/school network is blocking port 443 (not likely) you will get through, even if port 3389 is blocked you can do this to control your computer remotely (3389 is the remote desktop/remote assist port).-reply by aaron
how to bypass websense filter
EASY! right-click onyour desktop, then click on new shortcut.
Type "command" and press enter twice.
Double click on the short cut and type "ping" followed by space and then the address of the website your trying to access.
Right click anywhere in the window where you typed the text and click on "mark".
Highlight the series of numbers that appeared and press enter on your keyboard.
Open your web browser and paste the numbers into the address bar(usually ctrl+v).
Press the "go" button or press enter and
VOILA! one website that is not blocked!
**NOTE this does not always work**
easiest way to do it
Replying to iGuestReplying to wutskeReplying to wutskethe easiest way to bypass filters is to access the command prompt. If your school/work blocks it, open notepad, type "COMMAND.COM" and save it as a batch file (filename.Bat) the .Bat is the important part. After that you just double click on the file and it opens up the command prompt.
Next type tracert (the site you wants domain)(I'll use facebook)
"C:/WINDOWS/>tracert /?_fb_noscript=1;
(this will start to trace all the servers that your computer connects to to get to facebook)
"Tracing route to /?_fb_noscript=1 [69.63.176.140]
Over a maximum of 30 hops:"
Now copy (or remember) the IP address of the site, and type it into your browsers address bar.
I know for a fact that this works because I've done it on the computers at the health club I work at.
You have to be careful because you might be being watched by babysitter programs installed at a front desk or a teachers computer.
I never use proxies because they can be used to steal your passwords and other private information.
I also hear that if you put Firefox on a flash drive, websense won't be able to block it.
-reply by nathan
WEbsense Block / SSH TunnelingHow To Bypass Websense?
Hi ,Websense can take encryted web traffic with 7.0 versiyon , So you can't bypass it.-reply by Kemal Artıkarslan
If you have windows you should be ableto go to you're start menu, Go to Programs, Then accessories and find you're command prompt (or just go to run and type in cmd) type in ping then you're website name.
 Ex- if you want to go to myspace tpye in ping myspace.Com
This should come up with a four number code. Go to you're browser and when you are at you're adress bar type in http://---.---.--.--- and it should bypass the firewall each time you log on to the computer.
/txtmngr/images/smileys/smiley11.Gif /txtmngr/images/smileys/smiley7.Gif/txtmngr/images/smileys/smiley6.Gif/txtmngr/images/smileys/smiley5.Gif/txtmngr/images/smileys/smiley13.Gif/txtmngr/images/smileys/smiley15.Gif
Keywords:
Thanks to whoever gave the command prompt technique. It really helped me better than any other method I have used in the past.How To Bypass Websense?
-reply by Amy Keywords:
command prompt methodHow To Bypass Websense?Replying to iGuestI tried your method by writing tracert and the website to command prompt and I got this reply "unable to resolve target system name" for some reason. Can you tell me whats that about?-reply by maestro
how to How To Bypass Websense?
Hi, I have a problem in my city they have blocked almost 30% of the website like skype, facebook ... So , I have ADSL connection but without proxy settings so I can't break proxy  bqz I don't have proxy and if I try to use proxy my connection to internet shut down , I have a frind he told me if I change the ip addrees for my pc so maybe I'll be able to access the blockedSites , Please can anyone help me, is the ip idea is right,and if it right how can I do't and can anyone give my this ip.
-reply by Nour
These posts always make me laugh, You wont bypass websense if it has been installed properly, And if you do manage to get out by using a proxy it will then ban them.
Half of everything you read on these posts are plain ****, whether its http or https websense will ban it, it uses several techniques each one can be bypassed but the more you do it the quicker it will be taken away.
You used to be able to bypass websense by adding a // at the end of each domain or another . At the end but that has been fixed.
the ip address worked for about 2 weeks but then got fixed, the way it works with this is the browser takes the domain name and resolves to the IP for it, so, if you ban the IP on websense for facebook your not going to be able to get on there.
Where I work we can only access the company intranet which means there is no way out, at least with access to google I can get out by exploiting php boxs or running javascript in the address bar to connect to my home pc
-reply by S-Mug
 hey I'm 14 and at school figured out that if you reach an "Unrecognized" category for blocking then copy the URL that it blocked and then add a question mark (?) at the end of the URL. Without the parenthesis. Your Welcome :)
-reply by THE TECH God
How to bypass WebsenseHow To Bypass Websense?Well this is easy -_- when a website you want to visit is blocked, just copy the url, go to command prompt and type ping then take the ip address and copy it into the browser. Simple, easy, and I never, ever, got caught! (btw, this site was blocked too :P )-reply by Xtreme
 My school doesn't block this (idiots) but go to Tinyurl.Com. Next type the url that is blocked-hit make my url tiny, and it will give you a new url. Write it down and copy it to url bar and you can get anywhere! (Sorry if your business/school blocks this)
PS: Sorry Hyperlink wouldn't work.
Mikel-computer expert
