iGuest 3 Report post Posted June 23, 2011 mtu annoying stuff to deal with Need Help Changing MTU Settings For XBoxI have done everything that the iguest told me befor that said I have found out how to change mtu settings well I did everything an a black screen did pop up but I cant tell whats the (ure) I see the ip address but I cant tell what the ure port code is... Anybody open to share an tell me what it would look like.. -reply by brazilanhotness.. Share this post Link to post Share on other sites
iGuest 3 Report post Posted July 9, 2011 Connecting your xbox wirelessNeed Help Changing MTU Settings For XBoxReplying to Murphy11211You need to do is go access your router or modem. Go into gateway options then LAN ; then you need to find the NAT Pass through then to add your XBOX console Mac address so it would bypass your firewall. Don't forget your mac address needs to be type like this example 01:08:DD:09 ETC. And so on -reply by Gerardo Gonzalez Share this post Link to post Share on other sites
iGuest 3 Report post Posted November 18, 2011 mtu settingNeed Help Changing MTU Settings For XBoxhey I'm trying to connect to xbox live and I always get an MTU setting error. I go to change it and its already at 1492 and is greyed out (the txt is not black its grey) and I even get the same error when I connect it via cable. How do I fix this? how do I change my MTU setting properlyRouter/modem infoNetcomm nb6plus4w -reply by biggeffy Share this post Link to post Share on other sites
