MusicOnly
Can Someone Help Me Solve This Problem? joomla and smf
can someone tell me how to solve this problem? visit my site and go on forums
My Webpage
Might have a missing single or double quote is all. Something like that.Take ghostrider up on his offer.
did you implement a bridge component for joomla & smf? line 6 of that config.smf.php is basically just this:
The most likely cause is forgetting to close something, whether it be brackets, curly braces, quotes, anything. As the error is on line 6 it shouldn't be too difficult to look through the first few lines and see if you've missed something out. I can do the same as ghostrider, email or PM me (info in my profile) the code and I'll take a look.
Basically in php when ending a command you always have to use a ";" so in the example below you can see the semi colon goes at the end
RIGHT
echo "hello";
^^ that will display the word hello to the user
WRONG
echo "hello"
^^ that will give you an error the same as on your website
its very easy to fix as said, you could probably only copy and paste lines 5 6 and 7 of the file in question for it to be fixed, or maybe do it yourself if its a line like above but it might be a bit more complicated than that!
i installed my forum and i installed bridge between joomla and smf but when i try to configure smf bridge in joomla it shows that parse error...dont know what to do! it freaking me out!!!
Problem solved! I upgraded smf and then installed bridge. It works perfect!
Guest
