TheDisturbedOne 1 Report post Posted July 7, 2009 Call Apple! Many of the times, they will replace it for free. If they can't go to iresq.com and they have replacement parts (but they are a bit expensive).Why would you throw away an iPod? They are easily fixed or replaced, and if it is REALLY dead, recycle it and get 10% off a new iPod. No need to have more mercury contaminating our children's and grandchildren's water then there already will be.All iPods (at least since the second generation) are made in China, so there is no difference between an Apple iPod and a Chinese iPod. If you are talking about the rip-offs that aren't really iPods, I know what you are talking about. Share this post Link to post Share on other sites
iGuest 3 Report post Posted August 2, 2009 IPOD HELPIpod Not Working, Need Helpto fix the problem hold in the middle button and the play button for 5seconds. Should fix it up.-reply by craig Share this post Link to post Share on other sites
ASHISHRANJAN 0 Report post Posted August 18, 2009 hi................... you are in problem. iam here to solve your problem that how to cure your ipod. first of all go to the shopkeepern and then ask from him the reason for not working of your ipod and then give it to them to reparer it Share this post Link to post Share on other sites
TheDisturbedOne 1 Report post Posted August 18, 2009 As stated above, the best idea would be to go to the shopkeeper, which is Apple. Unfortunately they can't repair it on site. Share this post Link to post Share on other sites
iGuest 3 Report post Posted September 7, 2009 Busted ButtonsIpod Not Working, Need HelpI have had my 80gb Classic for about a year and a half, and last night out of nowhere the menu and center buttons stop working. I can't restart it with the hold on, hold off menu+center trick because like I said the buttons aren't working. And I've restored it like 3 times and it still isn't working. Does anyone have any way to fix it or should I just go to the apple store and see if they can fix it or get a new one.-reply by BlargJ Share this post Link to post Share on other sites
iGuest 3 Report post Posted December 25, 2009 how do i get it away ?Ipod Not Working, Need HelpEvery time I turn on my ipod touch it just comes up a picture of a usb cable and a picture of itunes what do I do ?/txtmngr/images/smileys/smiley5.Gif-reply by Nicole Share this post Link to post Share on other sites
sharetipsexpert 0 Report post Posted August 20, 2010 i think you should toggle the hold button then press the menu button and the middle button.it should restartif it doest contact applei hope this helps. Share this post Link to post Share on other sites
