DJCinnamonSnow
Fl Studio 9 Problem underruns
I have been using FL Studio for many years now and haven't had any problems with it. However, recently, I started having the problem of my music having a lot of buffer underruns on FL Studio when i play it. I don't understand why it all of a sudden has started happening bc it had never happened before. I am guessing that obviously something on my computer is robbing my cpu ram but I have no idea what. I checked my antivirus and antispyware programs and they seem to be doing the same as they have always done. I have avg free 2011 and spybot search and destroy and malwarebytes. I also have no messed with my sound drivers so I am baffled at why my FL Studio is all of a sudden having these buffer underruns. If anyone has any idea as to why this may be happening please let me know!
Have a look here : http://www.image-line.com/support/FLHelp/html/app_underrun.htm
If your CPU or disk usage climbs too high you are likely to experience audio 'buffer underruns' as clicks or pops in the live sound from FL Studio. The good news is that CPU and disk usage can be lowered considerably if you take the time to make some adjustments to the FL Studio Audio settings. The Audio Buffer is a temporary store of audio waiting to be sent to the soundcard, allowing FL Studio to even out momentary spikes in CPU load. If the Audio Buffer runs dry, because your CPU or hard-drive can't keep up with the 'real-time' audio stream, then your Soundcard will make rude pop, click or stutter noises. It is worth noting that underruns can ONLY occur in real-time playback, they will not happen while exporting to wave or mp3 file. If you do hear that sort of thing in an exported audio file, then it is likely a plugin behaving badly, check the plugin settings in that case.
They have a nice underrun optimization topic, depending from your audio drivers.Maybe this can help.
By the way, did you change something in your hardware, namely your sound card or your sound adapter?
Regards
Yordan
