WeaponX 0 Report post Posted February 4, 2007 Been thinking of using these converters on my IDE hard drives so they are 'SATA compliant'. I see that it will be using both the SATA type power connector and also a 4 pin (floppy drive type) connector. Have anyone used these IDE to SATA adapters before? Are both power cables required in order to make a drive operational? I will also be getting a SATA PCMCIA card for my laptop and that's where this will play a important role. I have no idea how to give it power if I want to use it as an external...what kind of cable to get for external use (4 pin connector)?A quick question on those y power cables. Will this supply enough power for the drives inside a computer? For example, I see one of those cables where they have one male 4 pin power cable that splits up to two SATA power cables. Just wondering if this will provide enough power for double the drive since it's really connected using one 4 pin cable from the power supply. Share this post Link to post Share on other sites
WeaponX 0 Report post Posted February 9, 2007 Just an update. I saw some y cables for the 4 pin (floppy drive) power connectors. It's going to be a bit clogged up with the extra cables, but it should work. Will test it when I get all the remaining parts and see how it goes. Share this post Link to post Share on other sites
Team Destiny 07 0 Report post Posted February 10, 2007 Eh it really shouldn't matter much IMO. Share this post Link to post Share on other sites
WeaponX 0 Report post Posted February 12, 2007 OK, just got all the parts in yesterday and didn't like it as much as I have anticipated. First thing to say is that one power connector will definitely not be enough power for the two hard drives...should have known that earlier. So I had to use two AC adapters for the two external drives with the y cables. Both of my IDE hard drives are converted to SATA type connectors.I thought the PCMCIA SATA card should have it's own dedicated bus for the two ports there, but it seems like they are still 'sharing' the throughput as I can't transfer files simultaneously without things slowing down.I haven't noticed much transfer speed increase either. Guess it's almost time to move on to SATA II and test that out Share this post Link to post Share on other sites
wutske 0 Report post Posted February 13, 2007 okay, time to wake up. Using a PATA > SATA connector will NOT give you any speed increase. It's not because you use a serial port > USB2.0 (if that might exist) convertor, that you'll be able to transfer data at 480Mbs over a serial port .Also, do not forget that SATA does not even offer a speed increase on drives sold nowadays. A good HDD transfer at MAX 70Mbs, wich is still below IDE100 or IDE133, so don't even think that SATA or SATA2.0 will give a speed increase.About the power cable, it has to give enough power, it's connected to your PSU, even the cheapest ones can power lots of hard drives without a problem. Share this post Link to post Share on other sites
WeaponX 0 Report post Posted March 13, 2007 Yeah, figured that was the reason why it wasn't as fast. I guess it just makes the PATA drives work on SATA only motherboards...But I have found that SATA is indeed much faster than the old IDE connections. I noticed this when I installed it into my desktop (instead of using it as an external drive) and installed Windows XP on it. It literally took only 20 minutes to install Windows XP on that SATA drive. This is using an actual SATA drive without any adapters/dongles/converters.The reason the power cable didn't give enough juice was because it was just a wall adapter one. You know, the ones that come with those IDE-USB Adapter cables I bought a few of those 2 in 1 four pin power cables/splitters and split them up like 2 times. Couldn't use more than one hard drive at the same time. I'm sure a low voltage power supply can handle this with no problems.How about the "dedicated" data line? Doesn't this apply to SATA? I thought that it can send and receive data at the same time without slowing things down? I know now that the converter won't make them the same speed, but would it actually SLOW transfer rates down on both ends if I connected this "SATA" drive to an actual SATA made hard drive on my SATA PC Card? How about the SATA PC Card itself? It's plugged into my laptop. Does it have SATA speeds if I just connect a original SATA hard drive to it?Thanks. Share this post Link to post Share on other sites
faulty.lee 0 Report post Posted March 17, 2007 WeaponX said: But I have found that SATA is indeed much faster than the old IDE connections. I noticed this when I installed it into my desktop (instead of using it as an external drive) and installed Windows XP on it. It literally took only 20 minutes to install Windows XP on that SATA drive. This is using an actual SATA drive without any adapters/dongles/converters.Actually i think the most important thing that determine the speed to the hard disk itself. Lately just bought a new Maxtor 80GB SATA2 8MB Cache drive, and i use it on my sempron 2600+ system. I find it quite fast. But later i got some problem with it, a bit of conflict with the mother board, and some trouble of booting up. So, I exchange with my friend for his Samsung one, same specs. It was working find. But then i realize i need more space, so i go back and change it to a 160GB Hitachi 8MB IDE. I took the ide one is to prevent having the same problem i had witj the maxtor. before i did the swap, i did some benchmark on the old drive. After i change to the new Hitachi drive, i did the same benchmark again using HD Tach. Here is the resultHitachi:Sequential Read Speed = 80MB/sBurst Speed = 124MB/sAverage Read = 64MB/sCPU Ultilization = 5%Samsung:Sequential Read Speed = 620MB/sBurst Speed = 190MB/sAverage Read = 50MB/sCPU Ultilization = 14%From the result, it seems that IDE is performing better that SATA except for Burst Speed. Burst speed is the raw bus speed. Which is how fast your hdd controller talks to the controller board on the hard disk. but if your hard disk can only supply data at a lower rate, that Burst speed is useless, except for if you're reading from the 8MB cache. Today's data on the hard disk are all quite big, in the order gig. 8MB cache is useless, so is the Burst Speed. the other thing is the CPU ultilization. Seems that IDE controller is quite optimized, where as SATA still need some improvement over it.As a conclusion, don't be cheated by the fact that SATA is faster, but take note of the speed of the drive itself. Share this post Link to post Share on other sites
wutske 0 Report post Posted March 19, 2007 For the "dedicated" data line part, I think it has something to do with the fact that you're using a PCMCIA SATA card. It's not that I'm saying PCMCIA is slow (in fact, it should be as fast as a normal PCI-bus), but I think (I guess) that PCMCIA isn't Full Duplex. This means it can't send and receive data at the very same moment, but it first has to send, then receive, send, receive ... wich causes things to slow down. Share this post Link to post Share on other sites
WeaponX 0 Report post Posted March 19, 2007 Hmm....one more question that's been bothering me. I know now that using these converters will not make them run at SATA speeds, but what speed will they be running in if I'm using it via the PCMCIA SATA card? I find it MUCH slower than my other hard drives which I use with a IDE to USB 2.0 adapter. Share this post Link to post Share on other sites
iGuest 3 Report post Posted August 12, 2009 To say SATA drives will not be faster then PATA is.. Well most likely wrong. While I agree that a hard drive is not likely to live up to the full speed of a PATA bus (although I don't know the details), what I can tell you is that PATA provides a shared bus where SATA does not. This means that only one drive can be accessed at a time via PATA if both drives are on the same bus. From the OS both drives appear to be openly accessable simultaneously, your speed will drop in half when you use them at the same time on PATA because the OS has to balance read/write back and forth between each one. SATA does not have this issue as each wire on a sata controller represents a different SATA bus. Also, although hard drives are the bottleneck of IO, two ways to speed them up are to invest in drives with a faster RPM and to invest into a RAID controller. Don't be fooled by motherboards that say they come with them because 99.9% that do have a "half" raid controller which is heavily dependent on software drivers and therefor not performing true RAID. Get a 3ware (now owned by LSI) 9650 or 9690 (I use both on servers I run) and setup a raid 5 or raid 6 controller between 3 or more drives. With RAID 5 you will have a speed increase as a multiple of the number of drives you have minus 1, I.E. 3 drives = twice as fast, 5 drives = 4 times as fast ...Approx, I should say almost that speed but not quite and not noticable enough for you to care. Also RAID 0 is faster but if a single disk fails on RAID 0 then all data becomes inaccessible. RAID 5 can support a minimum of 3 drives and has a total capacity of number of drives minus 1. So RAID 5 3 250GB drives will give you what appears as a single disk of 500GB. Raid 6 uses double parity and will give you a total capacity of number of drives minus 2 so 4 250GB drives on RAID gives you a total capacity of 500GB. RAID 6 needs at least 4 drives. Both of those 3ware controllers are hot swappable and just a couple nights ago I had to replace a hard drive on a RAID 6 file server. I removed the bad drive while the OS was running and put a new one in and the RAID controller rebuilt the missing data on the new drive and the OS never flinched or new that a drive was removed. Last thing to keep in mind, with RAID 0, 1, 5, 6 and maybe more, any disk is only seen as big as the smallest disk on the system so if you have a RAID 5 with a 100GB disk, 250GB disk, 500GB disk and 1TB disk, the RAID controller will only use the 100GB of each disk and will give you a total capacity of 300GB or 3 x 100GB with 1 disk size worth of data use for parity. Share this post Link to post Share on other sites
iGuest 3 Report post Posted December 8, 2009 how to transfer data from one hard disc to anotherIde To Sata Adapters & Power Cable SplittersMy old laptop is broken, motherboard is broken. I would like to find the way to transfer all my files from my old laptop hard disc to my new laptop. How can I do it? -reply by Pawel Share this post Link to post Share on other sites
iGuest 3 Report post Posted February 13, 2010 along same vein, ide an sata drives-w/controller on motherboardIde To Sata Adapters & Power Cable SplittersI have a compaq presario 6330ca with a maxtor 160GB Ide,running Vista and Windows 7,also just installed my other drive (sata)Maxtor 160 was used for storage on anther machine, I now want to run this sata drive as a linux machine after formatting. Will I have to disconnect one drive I.E the ide to run linux. Thank you.. Share this post Link to post Share on other sites
