iGuest 3 Report post Posted May 21, 2005 I am a beginner in the forum boards. I am looking for software that is easy to install and easy to configure.If you have any ideas please post. TY. Share this post Link to post Share on other sites
Trekkie101 0 Report post Posted May 23, 2005 SMF easily,Its in your control panel already but I have this tutorial which I made that you could follow.http://forums.xisto.com/topic/82440-topic/?findpost=1064293109Its step by step and ask if you have ANY trouble, the people here are well versed in the workings of SMF. Share this post Link to post Share on other sites
iGuest 3 Report post Posted May 24, 2005 Ty Trekkie101 your tutorial was excellent. Share this post Link to post Share on other sites
warbird1405241485 0 Report post Posted May 24, 2005 I suggest you use invisionfree. You don't need any scripting expierence or things and it's free, it's the same board Xisto use :B. Register here: http://www.zifboards.com/ Share this post Link to post Share on other sites
Hercco 0 Report post Posted June 3, 2005 To be fair, all the major bulletin board systems are really easy to install. If you are hosted here at asta, you can use Fantastico to install SMF, Invision or phpBB automatically, just filling out few form fields! It's actually easier to do than to register a one from invisionfree or other such service.What I suggest is that you look into the different systems, by visiting their official websites http://www.simplemachines.org/, https://invisionpower.com/features/apps and https://www.phpbb.com/ and check which has the features that suit your purpose the best. Also paying attention to what systems the forums that you visit use gives a pretty good idea of what each system can and can not do. And then, you could just go and install all of them, try them out, use the admin panels and changing the look to your liking... Then just pick the one which you like the most. Share this post Link to post Share on other sites
vujsa 0 Report post Posted June 6, 2005 Most of the Bulletin Board systems are easy to install and administer. I suggest not using invision your first time out simply because of all of the options availible to the admin. It can be pretty overwhelming for experienced forum admins.I really don't care much for phpBB so if you want a free forum I suggest SMF. Most of the options are pretty self expainitory and the application can grow as you see the need for add-on packages which by the way most are automatically installed and you don't have to know any code. Just download the package and then use the package installer.By the way, Invision is not provided in Fantastico any longer.Hope this helps, :Dvujsa Share this post Link to post Share on other sites
musichere 0 Report post Posted June 9, 2005 SMF is by far the best forum software for every purpose and best of all it's completely free and semi-open source.If you want a very very bare-bones forum software there are many that don't even use a database, just text files which are incredibly easy to mod and manage which I would recommend, but you'll find them lacking basic features that you need. Share this post Link to post Share on other sites
sagaxx 0 Report post Posted December 26, 2005 the most simply and free and great is phpbb , its wold wide , https://www.phpbb.com/ Share this post Link to post Share on other sites
