blix1405241486 0 Report post Posted April 3, 2005 Please help,my pc a p4, 3.2, 512mb, 120 mb with nvidia gforce4 suddenly behaves very funny. After restarting the pc only half of my desktop icons apear visibly and is´t not possibele to execute any one of them. Even restarting again all the icons apear but non is executable. Only after possibele the 5th restart everithing seem to work normal?! I have Zonealarm pro and panda platinum latest version running. I did a virus check wich turned out ok. Any Clue????Please help Share this post Link to post Share on other sites
arkad 0 Report post Posted April 3, 2005 You might wanna try to wait a lil longer before cliking .. sometimes if you have a lot of programmes running at startup .. it may take a while for all to load before your icons are workable .. Share this post Link to post Share on other sites
DonTravage 0 Report post Posted April 3, 2005 In have a similar problem, I found the best solution is to startup as normal, and then logoff, and log back on again (without shutting down the pc). My theory is that the startup from logon runs a different script thingy, and it stops my explorer crashing. If you cant click on 'start', press ctrl-alt-delete and choose 'logoff computer' from the 'shutdown' tab. Share this post Link to post Share on other sites
Trekkie101 0 Report post Posted April 3, 2005 Win XP has a rather annoying explorer, startup and searches are never ever gonna be good, best idea, is create a new profile and try that, its not likely to crash as easily, just share docuemtns/files as you need to Share this post Link to post Share on other sites
renshs 0 Report post Posted April 4, 2005 Yeah, when i upgraded my video card i had the same problem but mine also flickered and restarted atamaticaly. My problem was that one of my ram modules was faulty. but the pc still said that it had 512 once it was replaced it worked fine Share this post Link to post Share on other sites
tothefnmax 0 Report post Posted April 4, 2005 Try reformating your computer... most of the time, reformating solves a lot of problems... If you don't want to go through that hassel, i do not know what to tell you :/ Share this post Link to post Share on other sites
blix1405241486 0 Report post Posted April 4, 2005 In have a similar problem, I found the best solution is to startup as normal, and then logoff, and log back on again (without shutting down the pc). My theory is that the startup from logon runs a different script thingy, and it stops my explorer crashing. If you cant click on 'start', press ctrl-alt-delete and choose 'logoff computer' from the 'shutdown' tab. <{POST_SNAPBACK}> Thanks to all of you, i tried with your logoff/logon idea but i did not change a thing. Suddenly my pc behaves more funny, like my keyboard driver just changed. I think i will reformat the pc and install all the software new. hope it will help Share this post Link to post Share on other sites
linkinpark 0 Report post Posted April 7, 2005 I had a smilar problem like that but with the start menu what you do is go into safe mode and reinstall XP Share this post Link to post Share on other sites
blix1405241486 0 Report post Posted April 7, 2005 I had a smilar problem like that but with the start menu what you do is go into safe mode and reinstall XP <{POST_SNAPBACK}> Hi, thanks for the response. I actually did reformat my harddisk and reinstalled windows xp. Took quiete a while to get everything back to normal. At least now the computer seems to work like before.... Thanks anyway Share this post Link to post Share on other sites
