the_aggie10
Phpbb Forum Problem
ok, well when i went to my forums here it says phpBB : Critical Error
Could not connect to the database
whats happened? it was working great last night. thanks
Edited by KuBi
Cleared "[resolved]" (see edit history)
I'm pretty sure there is a problem right now with the MySQL database. Just be patient and I'm sure it'll fix itself or will be fixed by the admins shortly.
if you go to the top of the forums here and click on XISTO NETWORK and then just go to Server Network Status, and you will see that they are currently doing maint. on the servers so just be patient.
here is a direct link to view the server status
Edited by garbage (see edit history)
everything seems to be back up by now. problem resolved. closed. :lol:
Guest
