farsiscript
Flash Problem Plz Help
Hi All
I Design one website with flash header :: http://www.hugedomains.com/domain_profile.cfm?d=xmors&e=com for my friend but my friend can not see header flash , i design flash header by flash mx8 and my friend said can see another flash
but another friend can see flash
plz see this url :: http://www.hugedomains.com/domain_profile.cfm?d=xmors&e=com
and post here flash header is working true or not ?
Do You See Flash Header In http://www.hugedomains.com/domain_profile.cfm?d=xmors&e=com ?
Do You See Text in flash Like buttom text and Xmors Hosting ?
thanks all :angry:
Edited by .... (see edit history)
I can see the Flash header perfectly. lairz is probably right, but the problem may also be down to ad blocking software or a firewall. These can sometimes block Flash animations and animated images, and treats them as adverts. Make sure your friend allows your site to show Flash movies and animated images in their browser and any firewall, antivirus and ad-blocking software they may have.
Yep - seems to be working fine and looking as good as ever! itll be down to a different version of flash or some popup / activx blocker thingy probably.
You made the header with flash 8 right? Well if you just published your movie then you published it in Flash Player 8, if your buddy has Flash Player 7 he wont be able to see the header.You cand do two things, make your buddy to download the flash player 8 :angry: or you can publish the same header in Flash Player 7, you just go to File>Publish settings> in the flash option you can choose in wich flash player your movie will be published.The only problem is that if you used some of the new effects in flash 8 like, blur, glow, but i saw your movie and i dont think you used any of them.Hope i helped
Wow, your page is really really cool. I had a problem like this a while ago, it looked fine in my computer but in a friends computer it looked messed up. It was the flash player version he had. The problem was that flash player wasnt even informing him that he needed a new version. The best way to fix this version is explained in the next link:
please feel free to ask me if there is something that you didnt understand from it. :angry:
Thanks FLaKes , lairz , Jimmy , rvalkass , lairz , I Compile Flash Header in different Flash Player Version and my friend can see the flash but today i learn flash have bad compiler why flash is donig that !Why flash make once player to publish swf files ?thanks all
