DarKBLiZZ 0 Report post Posted January 11, 2006 (edited) Ok well i bought a script off the net and tried uploading it to my server and it gave me this error Fatal error: Unable to read 22293 bytes in /home/ancient/public_html/index.php on line 0so i contacted the guy who made the script and he said there was nothing wrong with the script and gave me a ftp to his account and told me to upload the it there and it works on there so i tried another script from another guy and i get same error you guys know anything about it???? Notice from BuffaloHELP: Moving from Xisto - Web Hosting > Technical Support to Programming. Edited topic title--"Help with a script" is aginst forum rules Edited January 11, 2006 by BuffaloHELP (see edit history) Share this post Link to post Share on other sites
conret 0 Report post Posted January 11, 2006 (edited) i might be able to help if you tell me what the script was made for and if its in another language then php Notice from jlhaslip: I have deleted the unneccessary double post that contained only the originating post from this topic.Verbal warning. Please only quote other post when neccesary. It clutters up the system and is hard on our members with dial-up. Edited January 11, 2006 by jlhaslip (see edit history) Share this post Link to post Share on other sites
jlhaslip 4 Report post Posted January 11, 2006 This member is hosted at Xisto - Web Hosting and as per the new format for the forum, he is here asking our advise and opinions. darkblizz: In order to assist you, please outline a few more details for the Xisto members to use in aiding you through this problem. What does the script do? What programming language is used? Are you connecting via ftp okay? Are the permissions on the account folder set correctly? We would like to assist, but need more info. Thanks. Share this post Link to post Share on other sites
DarKBLiZZ 0 Report post Posted January 11, 2006 umm sorry i have 2 scripts and both give same error i am hosting with computhosting i think how it was splet it said technial forum on therebut yea ok the forums i bought are for a clan and what i mean by clan is a bunch of gamers on battle.net i bought the scripots from darkactive.com and they told me i need zend installed so i contacted my host and they said it was so now i am posting here asking questions becasue he has no clue on whats going onthe script it uploaded at ancient-knights.com as soon as you go there you get the error i donno how to insatll it.he gave me a ftp account on his server to show me my script wasn't broken i uploaded it and it went o the install page i don't really know what else i can give you guys for information please ask me lots of questions so i can ask my host and the maker of the script to help me help you help me wow thats funny Share this post Link to post Share on other sites
jlhaslip 4 Report post Posted January 11, 2006 Darkblizz,First thing I think I would try is to un-install the script and then upload it to the public_html folder. sometimes these things don't like to be anywhere else.Try that and post back here. Or ask if they can send you a new version. It might have gotten damaged as it was uploaded? Share this post Link to post Share on other sites
DarKBLiZZ 0 Report post Posted January 11, 2006 umm thats where is it installed right now i wanted ti there so when i go to ancient-knights.com it would go to that page Share this post Link to post Share on other sites
jlhaslip 4 Report post Posted January 11, 2006 umm thats where is it installed right now i wanted ti there so when i go to ancient-knights.com it would go to that page 220120[/snapback] I understand that. It may be that something is messed up from the first install.An un-install and re-install may correct that. Share this post Link to post Share on other sites
Avalon 1 Report post Posted January 11, 2006 There could be a lot of reasons why the script will run on his server but not at Xisto - Web Hosting. I think the most likely scenario is the directory structure is different between the 2 servers, this could mean the script can't find the required files on the server it needs to run. I also suggest you look in the text of the script and see if it has any settings you need to change before you try to install, typically these will be commented lines for things like "Script Path", "Database Name", "Password" and the like. If you need help with what those settings should be you might need to ask Tech Support at Xisto - Web Hosting.Hope that helps. Share this post Link to post Share on other sites
jlhaslip 4 Report post Posted January 11, 2006 And if that fails, I'd be going back to the vendor and asking them to assist with this problem. If it is the script or the host, I am not sure, but the script supplier would be most familiar with the install of their product ( or should be), whereas the Host might not be.And furthermore, leaving you hanging isn't going t do their business ant good.They should be able to tell you exactly what that error message means and how to correct it.Good Luck. I'm off to bed now. Share this post Link to post Share on other sites
DarKBLiZZ 0 Report post Posted January 19, 2006 hey man thanks for all your help i found out it was a really really stupid reason why it wasn't working becasue the host has it so i have to upload it via ftp:// instead of using an actually ftp client so now it works i would like to thank everyone who tried to help me you guys were a big help for trying so i thank you all very much Share this post Link to post Share on other sites
