morpheus 0 Report post Posted January 1, 2006 I'm a counter-strike condition zero multiplayer newbie. I want to play it with some friends who are on the same network. I assume I start a server using hlds.exe. But how can others connect to this server? I've googled so many times, but am not able to locate a good guide that gets me started with CS multiplayer. Please help me get started on this. Share this post Link to post Share on other sites
Florisjuh 0 Report post Posted January 1, 2006 There is a "LAN" tab in the connect window. Share this post Link to post Share on other sites
PindleBoT 0 Report post Posted January 8, 2006 Are you using Steam or just Counter Strike 1.5? Steam is more popular now, it can be downloaded at steampowered.comOnce you've donwloaded and installed, follow the instructions to get into game. THere should be a LAN Tab at the top Share this post Link to post Share on other sites
amitojduggal 0 Report post Posted January 23, 2006 If you are using steam, Then only you can make a legal server, Steam is a software from valve, that keep tracks of various servers, If you want to make a server, youi must validate from valve and download there server software, that software allows you to connect and manage ytour server, But valve validation is a must.I think that will help you.Ok Bye Share this post Link to post Share on other sites
awpclan 0 Report post Posted January 30, 2006 yea go to http://www.steam-powered.com/ and then download steam and then there should b i think a hlds tab then update ur hlds....u might have an old version Share this post Link to post Share on other sites
amitojduggal 0 Report post Posted February 1, 2006 Steam Engine is better than the the counter strike 1.5 one, It alows us to get connected to the multiplayer servers, without launching them from within counter strike, And this also prevents cracked or unsafe servers, Prevents piracy in the sense. Share this post Link to post Share on other sites
abdalla agamy 0 Report post Posted February 8, 2006 Steam Engine : It alows us to get connected to the multiplayer servers Share this post Link to post Share on other sites
