johnenmarcel 0 Report post Posted May 15, 2005 How do you make a full flash site?can someone help me? Share this post Link to post Share on other sites
Inspiron 0 Report post Posted May 15, 2005 Hey...check this out...http://forums.xisto.com/no_longer_exists/ Share this post Link to post Share on other sites
johnenmarcel 0 Report post Posted May 15, 2005 do you know a free program? Share this post Link to post Share on other sites
badinfluence 0 Report post Posted May 15, 2005 Hey... check this out... http://forums.xisto.com/no_longer_exists/ 141701[/snapback] it's cool site... thks for sharing.... Share this post Link to post Share on other sites
round 0 Report post Posted May 18, 2005 I would suggest you try http://www.flashkit.com/.If you go into the movie section you'll be able to download fla files of just about everything including full sites, mind you that they're up for download by just about everyone so someone else out there may have the exact same site. It's also a great place to learn with all the tuts and just download fla files to see how other people do it.round Share this post Link to post Share on other sites
hayri 0 Report post Posted May 18, 2005 I think you have to buy dreamviewer mx. It should be quite simple and the best choice By the way: I liked 10minuteflash.com. I just made my own one, thanx for sharing this link Share this post Link to post Share on other sites
Tyssen 0 Report post Posted May 18, 2005 I think you have to buy dreamviewer mx. It should be quite simple and the best choice. You can't make Flash sites using Dreamweaver. You need Flash (or maybe SwishMax) to make Flash sites. Share this post Link to post Share on other sites
Lessur 0 Report post Posted July 25, 2005 It's simple actionscript with buttons like "gotoAndPlay". If you want to make a 'swish' like site.... well I cant help you there because it involves more coding than I know. Share this post Link to post Share on other sites
Lessur 0 Report post Posted July 25, 2005 If you get flash: Â You can't make Flash sites using Dreamweaver. You need Flash (or maybe SwishMax) to make Flash sites. 142717[/snapback] Share this post Link to post Share on other sites
ArMs 0 Report post Posted July 31, 2005 yeah u need flashto make a flash site but u may use dreamweaver to upload the flash images or w/e. And by the way flajs is tuff,lol so gl Share this post Link to post Share on other sites
sangdukseo 0 Report post Posted September 17, 2005 if u need help, ask me. i'm good at flash and actionscript, the coding script language of flash Share this post Link to post Share on other sites
psychiccyberfreak 0 Report post Posted September 17, 2005 there's a free online flash site template. It's ok, but if you want you can use one of the tutorials at flash kit.the site is http://forums.xisto.com/no_longer_exists/ I think. Share this post Link to post Share on other sites
far3 0 Report post Posted October 15, 2005 I would rather learn it the hard nitty gritty way then using this POS Share this post Link to post Share on other sites
