spawN-eD
Need Help
hi all Xisto users , admins , mods ;) i didn know where to write this but i will try here ;)so story is simple :lol: i got made .bat file who receive OS version , computer name and ipconfig and its saving to %computername%.txt now i have a question and thats sounds like this:After .bat file start it will do the job but not save to .txt but send info to php or mysql to other pc or server where is that mysql database is that posible? and how? explane me or show some simple :lol:sory my bad english
Is it really necessary to use a .bat file?
More precisely, isn't this a homework you have to do at school?
Isn't it simpler to let the php program do the job and insert the result inside the database?
hi all Xisto users , admins , modsi didn know where to write this but i will try here
This topic is not a tutorial. So, you are right, you should not have posted it in the tutorial section. ;)
Sorry, but, this is quite not clear.the wget sentence is easy to put in a .bat file.What we cannot understand is what you want to be done. Why do you need a mysql database?And what is the operation that has to be performed. Do you want to save on your server the contents of the whole PC of each guy accessing your website?Why do you need to store the IP address, password and start a wget remote backup?You know, we cannot fully help you if we do not fully understand what you are wanting to be performed.
im computer tehnic and we got clients show live in citys who are far away from us and if something happens thos that pc maby we can user vncviewer and that peoples dont know where to see ip and etc ... so we want make programm wich will launch at pc start and send info about this user so that info will save in mysql or etc and displays in some php file
OK, now we see what you want to do, this can be done very easily.
You can do this very easily in a bat file.
This bat could be something like this, and could be easily sent at the end of system boot.
ipconfig >myip.txtscp myip.txt remoteuser@remoteserver:myip.txtecho ip sent to remote server
Of course, you will have to install scp for windows on your customer system (a free version), and setup scp signatures for unattended send, but this is a standard system administration task.
Regards
Yordan
btw i forgot to say that the server on what i want to send info is based on gentoo system
for a while i got something like this :
@echo offecho [*] Collecting Relevant system informationecho Host Name : %computername% > %computername%.txtsysteminfo | find "OS" >> %computername%.txtsysteminfo | find "Domain" >> %computername%.txtipconfig | find "IP" >> %computername%.txtecho. >> %computername%.txt
i made it just for tests and maby what info send to my server
Edited by spawN-eD (see edit history)
This is perfect, and should work with your gentoo system.Just have a look at the resulting file to check that all your infos are there, manually check the scp syntax in order to validate your hostname and username settings, and then add the scp line inside your script.
heh tnx ;) but i have wondered about one thing if the pc got password protected and its got sleep maby is some way to get that password at pc start when user write it or maby its saving in some file
I am not talking about the PC's admin password.I am talking about a password on your gentoo system for the customer filesystem transfer.Let's say I create a user named "spawned" on your gentoo system.Then, the PC makes a scp myfile.txt spawned@yourser:myfile.txtThe only password which has to be sent is the spawned's password on the gentoo system. And this gentoo user spawned is a user which is only allowed to store the text files received from your customer's PC. And of course this text file should have nothing secret, so that if some spy is listening to your customer's phone line he can catch nothing precious.
You don't need the client PC admin password, you only need his IP.At least you don't need the PC to send his password through the network, you need the customer to tell you his password through a secured way (while having a coffee together for instance), you only need the current IP to be sent at boot time.And on the gentoo system I was not talking about the root password, I was talking about a dedicated user's password, this user owning the transferred files. Such a user cannot touch the system files, he can only touch the transferred files.
