TavoxPeru 0 Report post Posted July 12, 2007 (edited) What i want to do is to first enabled a disabled text box, and then focus and select all the contents of this text box after the user clicks on a checkbox, i have it working with simple HTML and Javascript but how can i do to get the similar result using the DOM??? For simplicity i only include this code that works: <html><head><script type="text/javascript">function toggle(formname,checkname){var c="CantField"; if(checkname.checked==true) { checkname.value="on"; document.f[c].disabled=false; document.f[c].focus(); document.f[c].select();}else { checkname.value="off"; document.f[c].value="0"; document.f[c].disabled=true;}return;}function init(){document.f.CantField.disabled = true;}// using DOMfunction initD(){document.getElementById('CantField').setAttribute("disabled",true);}function toggleD(formname,checkname){var c="CantField"; if(checkname.checked==true) { document.getElementById(checkname).setAttribute("value","on"); document.getElementById(c).setAttribute("disabled",false); document.getElementById(c).focus(); document.getElementById(c).select();}else { document.getElementById(checkname).setAttribute("value","off"); document.getElementById(c).setAttribute("disabled","true"); document.getElementById(c).setAttribute("value","0");}}</script></head><body onload="init()"><form name="f" action="page.php" method="post" ><input type="checkbox" value="off" name="CheckField" id="CheckField" onclick="toggle('f',this)" /><input type="text" name="CantField" id="CantField" value="0" /><input type="submit" value="Check Out" name="submitCar" /> <input type="button" value="Cancel" name="cancelCar" onclick="java script:this.form.reset();"></form></body></html> I know that this code must be optimizied but it is only for simplicity because it is a very heavy form. When I use the toggleD() function the select method dont work, why happens this??? Am I doing something wrong??? Best regards, EDIT: Well, i can't find a solution to the DOM problem so i decide to not use it basically because the select() doesn't work in any manner, if someone get the solution please post it. Edited July 17, 2007 by TavoxPeru (see edit history) Share this post Link to post Share on other sites
