Vyoma
Problems With Creating Account I think I have problem creating account.
I am having problems with the Step 2 of the How To Activate Your New Hosting Account Guide.
When I enter all fields and press submit, I am getting the following window:
http://forums.xisto.com/no_longer_exists/ DOES NOT APPEAR TO BE A SUB-DOMAIN OF Xisto
Xisto DOES NOT REGISTER DOMAINS FOR YOU.  IF YOU HAVE ALREADY REGISTERED THIS DOMAIN AND WANT
TO USE WITH YOURS HOSTING, PLEASE ENSURE THAT YOU HAVE POINTED YOUR DOMAIN NAMESERVERS to
NS1.TRAP17.COM and NS2.TRAP17.COM.  Please allow atleast 2 days for propagation.
[OK]
Should http://forums.xisto.com/no_longer_exists/ appear to be a sub-domain of Xisto?
I hope you went to the page: https://support.xisto.com/ - right ?
If you're getting this message there - no problem - once you reach this message, press ok and wait. It might take upto 15minutes to finish everything regarding creation of your account.
Xisto and Xisto - both use the same scripts for these operations. New scripts are first tested in trap and then used here. Quite often, you'll find the messages relating to trap haven't been changed - but it's not really of any significance. It'll work just fine.
Try and let me know.
Yes, I went to the page: https://support.xisto.com/
Then, I choose, #1.Create a Hosting Account
Please Enter your Forum Username: Vyoma
Please Enter your Forum password: <My Xisto Forum password>
Domain: http://forums.xisto.com/no_longer_exists/.kmaheshbhat.astahost.com
The message box confirms it.
Enter a Username ( max. 8 characters allowed ): Vyoma
Enter a Password for your Account : <My desired account password
I press submit, the above stated message appears.
[OK]
I press OK.
Script prompt comes:
Script Prompt:
Proceed to Create Website (http://forums.xisto.com/no_longer_exists/) Please      [OK]
Type "YES" to confirm and continue..(it may take several minutes to process [Cancel]
[undefined]
I type "YES" (without quotes) and Press the [OK] button.
It is takes some time, and I wait patiently. :)
Then it shows this page (Formatting and passwords removed):
Xisto
Processing.. Please Wait. It may take 10-15 Minutes. Do not press STOP or RELOAD, You may lose your token.
Username passed validity tests.
Connecting to database..
Connected.
Verfying member status..Member Validated.
Checking permissions
Permissions granted.
Checking if username is Unique.
Username seems to be Unique.
Data prepared for sending to Server.
YOUR ACCOUNT WILL BE PHYSICALLY CREATED ON THE SERVER AND APACHE SERVICE WILL BE RESTARTED!!
THIS PROCESS TAKES VERY LONG TIME. PLEASE BE PATIENT. DO NOT HIT RELOAD OR STOP.
REQUEST SENT!..WAITING FOR REPLY....
REPLY RECIEVED! ANALYZING DATA.
ANALYSIS REPORTS, YOUR ACCOUNT HAS BEEN CREATED SUCCESSFULLY
Reconfiguring User information..
Configuration Complete
Showing Final Screen with Process results from server.
Xisto.com : Free Web Hosting Account Activation
Please Enter your Forum Username Vyoma
Hosting Account Domain kmaheshbhat.astahost.com
Hosting Account Username  vyoma
Hosting Account Password <password I had asked for>
:: Hosting Account Details :: ( Please save it )
WWWAcct 10.0 © 1997-2005 cPanel, Inc.
| New Account Info |
| Domain: kmaheshbhat.astahost.com
| Ip: 64.69.46.210 (n)
| HasCgi: y
| UserName: vyoma
| PassWord: <password I had asked for>
| CpanelMod: rvblue
| HomeRoot: /home
| Quota: 150 Meg
| NameServer1: ns1.astahost.com
| NameServer2: ns2.astahost.com
| NameServer3:
| NameServer4:
| Contact Email:
User vyoma added
Changing password for vyoma
Password for vyoma has been changed
Removing Shell Access (n)
Changing shell for vyoma.
Shell changed.
Copying skel files from /home/Xisto/cpanel3-skel/ to /home/vyoma/
Using Quota v3 Support
Added Entries to httpd.conf
Bind reconfiguring on gamma using rndc
Bind reconfiguring on alpha using rndc
Added Named File
Using Frontpage 5.x!
Starting install, port: 80.
Creating web http://forums.xisto.com/no_longer_exists/.
Chowning Content in service /.
Install completed.
Setting Password
Frontpage passthough auth enabled!
Restarting apache
Ftp Password Files synced
Vhost Passwords synced
wwwacct creation finished
Account Creation Complete!!!
Access Cpanel at http://forums.xisto.com/no_longer_exists/ or http://forums.xisto.com/no_longer_exists/
You can access ftp at ftp.kmaheshbhat.astahost.com.com
Your MAIN FTP username and password are same as your cpanel username and password.
Please save all the above information.
Hope now that it is all right.
P.S: I am not putting the passwords not because that I do not trust you, but there are others and forum boards are not safe.
Yes, m^e. I was able to access my cPanel. Everything seems fine now. I am off to designing my website.
Moderator may close this thread. It has served its purpose.
Shoot! I should not have said that. Sorry for double posting, but I seem to be having a problem with the cPanel now.
When I try to access http://forums.xisto.com/no_longer_exists/, I get the follwoing error:
The page cannot be displayed There is a problem with the page you are trying to reach and it cannot be displayed.
Please try the following:
Open the http://forums.xisto.com/no_longer_exists/ home page, and then look for links to the information you want.
Click the  Refresh button, or try again later.
Click  Search to look for information on the Internet.
You can also see a list of related sites.
HTTP 500 - Internal server error
Internet Explorer
Must have been a temporarily problem with the server yesterday.. i can access it now. Try again and see :)
1064331348[/snapback]
I tried it again. It is showing the same message. It is not even showing the pop-up that asks for username/password.
It's working for me as well. If you are using Firefox, try emptying the cache, close all firefox windows and then try to open it again. Or try it in IE or Konqueror or some other browser.
Can you try using firefox instead once ? None of us are having the problem with firefox. In case you can't use anything other than IE, let me know, I'll see what can be done.
Also try accessing it through: http://forums.xisto.com/no_longer_exists/ and see if it works.
1064331360[/snapback]
I actually do not have much of a choice on the browser, since I do not have a PC and internet connection at home. But I think, I do know the problem.
It may be due to firewall issues on that particular port from where I browse.
I will try from somewhere else and then let you know.
