Casanova1405241497
Please Help Me Out With Typing Problem
Hello Friends Well my problem is very Funny one which iam facing since Childhood,I dont know the fix for it,Hope someone here can help me out ,Just for an example think i have to type a matter in a mail or notepad,I type everything First,but the real problem comes When i try to edit the text -For example,this is bad problem,{i have to replace bad with good} So i click and start typing,And it comes this way-- this is goodproblem,{Saw that by typing its deleting the words in front of it..! Even if i try putting space inbetween good and problem , I will end up loosing alphabets from "problem" Sorry frenz im bad at explaining but this is the real problem bugging me .! Actually i face it sometimes and Sometimes Its fine,Not only on this system but all of them same problem,, Wanted to know if there is any Shortcut which will stop replacing of words if i want to edit?hope you got what my problem is..! Plz do ask me if you have not understood till now,Thanks,Casanova
lol i know what u mean .. m8 .. i go thru the same problem sumtimes .. but the only thing i do is either copy the whole thing i typed .. close notepad and restart notepad and paste and start typing again and its fine .. or .. if tat dosent work .. i just restart the PC .. and it works fine for me .. lol i havent gone into askin ppl y this is so .. but i like the effort u made .. hope u get ur answer soon .. it mite help me too :D ..Cheers
Lol, I can imagine this woud be very frustrating, here's how to solve the proble; press the Insert button on your keyboard. Now try correcting your mistakes, it should be fixed.It's caused because having the insert mode on means that when you type it just overwrites anything after it, instead of putting it in before the rest of the text.Hope this helps! :D
Well infamousflame and dhanesh thanks for the reply.... yeah But the insert buttone one i will test next time as i encounter this problem,I dont think thats the reason as i never use insert button, Actually i got really bored in yahoo chat,Where we cannot move down by pressing enter, So it really creates problems To edit,Im happy that u got the problem.. If funny on Which i tried to solve since my childhood.... Now i feel that maybe bill-gates might not be knowing a solution .... lolAnywayz infamousflame Bro .. i will let u know as soon i check if its fine or not..! Right now its fine... Soon Will encounter i guess.! :D Thanks for ur supportCasanova,
It seems to be either more of a problem with the software or editor and possibly some settings because notepad Wordperfect, Word or just about any word processor will have a default the allows inserts without having to do anything.When you want to edit something try highlighting the area you wish to correct and just type in the new text. To highlight either left click and hold down the left mouse button or hold the shift key while using the appropriate updown or left right keys then after typing in your correct text if you notice text adjacent to it disappearing then just press the ins or insert key (after you go to edit and undo your last action). and you should be alright. then You might need to look at your preferences or options of the editor and look at insert or delete or ins del and see what is happening.
Hope this helps! :P
<{POST_SNAPBACK}>
Yes, the insert button was the first thing I was thinking as the problem to.
I'm wondering why this happens with her though?
With me, I only get the problem using corel word perfect (which works great).
Never has it happened to me outside of that program. So it's a little weird that it happends to her so often :S
Oh well, should be solved now though.
Thanks for posting so fast inflamous :D
Actually, I have the same problem. I will be typing a school paper, and in the beginning it is fine. But because I type very fast, and I look at the keyboard (habit from playing games), I don't see errors and sometimes I will go back, strart typing, and lose a whole paragraph! I would suggest pressing insert when it happens again, then getting a knife, and wedging out your insert key! Yes, I have done this. Since then, I haven't had a problem. But, if you still have a problem, I advise you contact microsoft Support or a local technology store. You may just have a defective keyboard, or maybe a partially defective system.
As you have said that this problem comes on all of the systems not only a particuler system so I don't think that this is a problem of any type of software or hardware malfanction.Although you have written than Insert button is not creating this problem but I will still insist that the problem is only due to insert button. No other thing comes in my mind for this. Whenever this problem comes in front of you press Insert button for once and I hope your problem will be solved.
yes infamousflame,Houdini,spacewaste,Xcl and solanky... yeah you all said right.. Today i encountered the same problem.. After pressing insert button it vanished..! And now Everything is fine.!Thanks infamousflame For a pretty fast reply.. Finally i got the solution to this one thanks frenz.. @dhanesh hope your Problem might be solved by now.. :PThanks for the help dear frenz..! :D
lol casanova .. i was typing a reply saying that " No i havent gone tru it but when i do i'll check this out " fortunately while typing this .. the phenomenon started lol .. and i did what infamousflame said .. really that works :P .. ok well so now i dunt have to copy and past the whole stuff again and waste my time then .. Thankx alot infamousflame .. and all the other inputs that came in .. woow .. i feel saved .. and i learned sumthing new :DThankxDhanesh
Hahahaha!! Wooh!! This is so funny! I had the same problem since I was a kid. When I was typing in Word 95 and needed to change something in the text, it would happen the same thing like what happened to you!! :P :PYes, they're right. You'll have to press the "Insert" button, above your arrow keys. I learned of this about several years ago. Bah, what a doofus I am!! LoLIf it doesn't solve your problem, then you'll need a system wipe :D
I used to have the problem when i was a kid and i accidentally found out it was a problem with insert Key when i was using an MS-DOS Program where the cursor changes completely when insert is pressed and when pressed again it returns back to normal.
