rhodesian.dragon 0 Report post Posted April 18, 2005 Every time I try to use my FTP account I keep geting an error: the connection attempt timed out. I get this same error every time I try to see my site also. Can anyone help me...? Share this post Link to post Share on other sites
ebbinger_413 0 Report post Posted April 18, 2005 idk...are you using an ftp program ? Share this post Link to post Share on other sites
iGuest 3 Report post Posted April 18, 2005 Everyone's site is down, including mine. My website has been down for nine hours+. Hopefully, everything will be back online soon. Share this post Link to post Share on other sites
Analyst 0 Report post Posted April 19, 2005 Did this ever work? Is you username and password correct? What clinet are you using? What OS (can you access the low level FTP client in Win*** and use that to test the client? Any more info ? We can not really help with what you have given us. Regards Every time I try to use my FTP account I keep geting an error: the connection attempt timed out. I get this same error every time I try to see my site also. Can anyone help me...? <{POST_SNAPBACK}> Share this post Link to post Share on other sites
rhodesian.dragon 0 Report post Posted June 17, 2005 I am still having problems using FTP. It was working before 04-18-2005 but then stopped. I keep getting an error: the connection attempt timed out. I tried using an FTP program LeechFTP, also I tried using IE and typing in the FTP address, I also tried using an online FTP site http://forums.xisto.com/no_longer_exists/ but no matter what I do I keep getting the same error. My OS is Windows XP I also tried using my Mac OS X with fetch but again same problem occurs.I know that my user name and password is correct I even tried changing the password and even tried creating a new FTP account but again the same problem occurs... Share this post Link to post Share on other sites
vizskywalker 0 Report post Posted June 17, 2005 rhodesian, I'm having a similar problem. See if you can use the comand prompt ftp commadn to get in.~Viz Share this post Link to post Share on other sites
rhodesian.dragon 0 Report post Posted June 17, 2005 rhodesian, I'm having a similar problem. See if you can use the comand prompt ftp commadn to get in. ~Viz <{POST_SNAPBACK}> I was able to use the Command Prompt FTP to get in with no problem. Share this post Link to post Share on other sites
vizskywalker 0 Report post Posted June 17, 2005 I have the same problem, text based ftp like command prompt or the linux variant work fine, but graphical ones don't. Very puzzling and annoying. Maybe I'll have to make an http ftp so people won't have to worry about this problem.~Viz Share this post Link to post Share on other sites
rhodesian.dragon 0 Report post Posted June 17, 2005 I was able to use the Command Prompt FTP to get in with no problem. <{POST_SNAPBACK}> I hate to double post but I was able to log in but I am not able to upload or download any files. Share this post Link to post Share on other sites
vizskywalker 0 Report post Posted June 17, 2005 the put and get commadns weren't working?~Viz Share this post Link to post Share on other sites
Neverseen 0 Report post Posted June 20, 2005 I can't login to my FTP using FlashXP... But the website works fine as well as cPanel.. weird If anyone has any idea about the issue, please post here, Share this post Link to post Share on other sites
warbird1405241485 0 Report post Posted June 20, 2005 I don't know if you have uploaded before with Flash but if you haven't try another FTP-program. If you have then it's maybe because the server has some problems today, like M^E already said in shoutbox. Share this post Link to post Share on other sites
edskii 0 Report post Posted June 20, 2005 Try using these different FTP clients.https://www.globalscape.com/cuteftphttps://www.smartftp.com/Both very good programs. You can at least try them Share this post Link to post Share on other sites
rhodesian.dragon 0 Report post Posted June 20, 2005 the put and get commadns weren't working? ~Viz <{POST_SNAPBACK}> No the put and get commands did not work for some odd reason I even tried to use the mput and mget but again they did not work. I don't know if you have uploaded before with Flash but if you haven't try another FTP-program. If you have then it's maybe because the server has some problems today, like M^E already said in shoutbox. <{POST_SNAPBACK}> Try using these different FTP clients. https://www.globalscape.com/cuteftp https://www.smartftp.com/ Both very good programs. You can at least try them <{POST_SNAPBACK}> I did try mulitple FTP programes and they all give me the same problem and messages like: "An error occurred opening that folder on the FTP Server. Make sure you have permission to access that folder. The operation timed out." "! Socket Error: operation timed out or aborted ~ Could not retrieve directory listing for "/" ~ Disconnected" so on and so on... I do not think that the FTP program is the problem. This problem has been on going from 04-18-2005 Share this post Link to post Share on other sites
rhodesian.dragon 0 Report post Posted June 21, 2005 I think that I have found a solution to this problem. I do not know if this will work for everyone but it worked for me... I was playing around with different settings in windows and one thing I did was disabled the firewall. After I disabled the firewall the FTP worked fine... I was able to upload and download files from the server using FTP. The problem was gone. So I guess that every time I want to use my FTP account I will then have to disable my firewall. I think that this solution is a little odd? Share this post Link to post Share on other sites
