cncinfotech
Mysql-essential-5.0.51 Installion Problem please help me.(urgent)
Dear friend, please help me. Iam working on php project (matchmaking site). I have downloaded mysql essensial 5.0.51. When i was installing mysql 5.0.51, i got following error - Error 1901: Error attempting to read from the source installation database: c:\windows\installer\527ec6.msi [retry] [cancel] What is solution of this problem ? Iam using windows xp professional version 2002 (service pack 2).Please post your reply.Iam waiting for your answer.
Edited by cncinfotech (see edit history)
Or, as an alternate option.
Go to http://www.mysql.com/ and download *.zip files.
Place it on your hard drive and extract by a zip app such as winrar or winzip or windows build-in zip feature from windows xp.
After that, please make a copy of my*.ini and place it to your windows xp system folder. That will be windows if you have not change it's name when you install it. A my-small.ini should enough on most situation if you use it for development only.
Finally, change folder to {MYSQL-DIR}\bin\ and type in mysqld-nt and press enter.
or run it as a windows service by execute this command:
mysqld-nt --install
and start it by use
net start mysql
Following are all steps:
Let's say mysql will be installed on c:\mysql\ folder, then hereafter, when I use {MYSQL-DIR}, it will represent this directory.
extract files metioned above, then,
C:> cd {MYSQL-DIR}\bin
C:\mysql\bin> dir03/18/2006  04:20p	  <DIR>		  .03/18/2006  04:20p	  <DIR>		  ..03/09/2006  11:10a		   1,175,552 comp-err.exe03/09/2006  11:10a		   1,302,528 libmySQL.dll03/09/2006  11:10a		   1,413,120 myisamchk.exe03/09/2006  11:10a		   1,318,912 myisamlog.exe03/09/2006  11:10a		   1,335,296 myisampack.exe03/09/2006  11:10a		   1,298,432 myisam_ftdump.exe03/09/2006  11:10a		   1,359,872 mysql.exe03/09/2006  11:10a		   1,269,760 mysqladmin.exe03/09/2006  11:10a		   1,290,240 mysqlbinlog.exe03/09/2006  11:10a		   1,261,568 mysqlcheck.exe03/09/2006  11:10a		   6,283,264 mysqld-debug.exe03/09/2006  11:10a		   4,472,832 mysqld-max-nt.exe03/09/2006  11:10a		   4,468,736 mysqld-max.exe03/09/2006  11:10a		   3,977,216 mysqld-nt.exe03/09/2006  11:10a		   3,973,120 mysqld.exe03/09/2006  11:10a		   1,298,432 mysqldump.exe03/09/2006  11:10a		   1,265,664 mysqlimport.exe03/09/2006  11:10a		   1,310,720 mysqlmanager.exe03/09/2006  11:10a		   1,265,664 mysqlshow.exe03/09/2006  11:10a		   1,363,968 mysqltest.exe03/09/2006  11:10a		   1,601,536 mysql_client_test.exe03/09/2006  11:10a			  40,960 myTest.exe03/09/2006  11:10a		   1,171,456 my_print_defaults.exe03/09/2006  11:10a		   1,150,976 perror.exe03/09/2006  11:10a		   1,171,456 replace.exe			  25 File(s)	 47,841,280 bytes			   2 Dir(s)	   4,235,264 bytes free
C:\mysql\bin> mysqld-nt --install
C:\mysql\bin> net start mysql
That's all steps.
Eric,
