allord 0 Report post Posted February 9, 2008 I have a problem, I want to work with PHP5 , but my last scripts dont wana to run with it and I cant find solution. Can anyone help me solve my problem? Share this post Link to post Share on other sites
jlhaslip 4 Report post Posted February 9, 2008 Might be able to assist you if you were to tell us the name of the script, or perhaps show us some code, or maybe what version of php it actually does run under? Is safe mode on or off where you are running it? Is Safe Mode required? Is there a database required?Too many questions, not enough answers... Share this post Link to post Share on other sites
hitmanblood 0 Report post Posted February 9, 2008 Well would you care enough to allowe us see parts of the script because there might be some method that are now obsolete or something similar. Or it is just that php script is not correct. Elaborate your problem more to get accurate response. Share this post Link to post Share on other sites
it01y2 0 Report post Posted February 12, 2008 Well would you care enough to allowe us see parts of the script because there might be some method that are now obsolete or something similar. Or it is just that php script is not correct. Elaborate your problem more to get accurate response.I would try and find a php converter on the internet, I have seen one before on the internet. Share this post Link to post Share on other sites
