mrdee 1 Report post Posted October 13, 2007 I am frantically trying to get into my Trap 17 control panel.I tried to get into the login screen by typing:http://forums.xisto.com/ and indeed, the login screen comes up.I then type in my username (mrdee, or should it be my trap 17 domain)?I then also enter my correct password, what hapeens then is that the login screen keeps popping up again.I have no idea what I am doing wrong.Can anyone help me please?Thanks in advance. Share this post Link to post Share on other sites
serverph 0 Report post Posted October 13, 2007 Complete Instructions And Settings For Hosted Membersthere is flash tutorial of sorts dealing with cpanel also. just go the the part near the end where cpanel is discussed:http://forums.xisto.com/no_longer_exists/ Share this post Link to post Share on other sites
Forbez 0 Report post Posted October 14, 2007 Think you've been hacked mate. Happened to me. Share this post Link to post Share on other sites
mrdee 1 Report post Posted October 14, 2007 Think you've been hacked mate. Happened to me.Thank goodness that was not the case, Forbez.Thank you for your advice, serverph, I found the solution there. Share this post Link to post Share on other sites
velma 6 Report post Posted October 14, 2007 Topic is resolved.Please PM any moderator to continue this discussion. Until then, this topic is closed. Share this post Link to post Share on other sites
