BooZker 0 Report post Posted June 28, 2006 Well if you go to my site http://forums.xisto.com/no_longer_exists/ and go to the home page you'll see the main nav bar above. With Home, Pictures, Video etc. I want to put a Forum button, but i have a lot of pages and i don't wanna put it in the nava bar in every page. I have like 50 pages (Under videos you'll see video pages on the left. That's a lot of them) So is there any easy way of putting it in all the pages without opening each webpage and adding it? I have Dreamweaver 8 also if you know how to do it with that.If you know how THANKS A LOT. Check out my forum also haha http://forums.xisto.com/no_longer_exists/ Share this post Link to post Share on other sites
illdevilinc 0 Report post Posted June 28, 2006 Well if you go to my site http://forums.xisto.com/no_longer_exists/ and go to the home page you'll see the main nav bar above. With Home, Pictures, Video etc. I want to put a Forum button, but i have a lot of pages and i don't wanna put it in the nava bar in every page. I have like 50 pages (Under videos you'll see video pages on the left. That's a lot of them) So is there any easy way of putting it in all the pages without opening each webpage and adding it? I have Dreamweaver 8 also if you know how to do it with that.If you know how THANKS A LOT. Check out my forum also haha http://forums.xisto.com/no_longer_exists/Im not sure how to slove your problem right now, but there is a way that you can solve future problems like this. I recommend you put the navagation and the O&J Production image in a header. Im not sure if Dreamweaver will do this but with Microsoft Frontpage (if you have it) you can make a header and the header will automaticly go on everypage you have in that site. But the only problem with that is that you will have to delete the header and the image from every other page. But, after you get threw all of that you can simply use your header to make all changes to your navigation. If you want to do that but dont have frontpage let me know in a PM and i may be able to help you.P.S. I am a Dreamweaver and Frontpage user Share this post Link to post Share on other sites
BooZker 0 Report post Posted June 28, 2006 OK i think ill PM you. Thanks. If there is anyone else that might know how to fix this post it please. Share this post Link to post Share on other sites
uiop 0 Report post Posted June 28, 2006 I'm sorry if I didn't understand your question completely, but I'll try to answer it.I belive that you could use something called SSI (Server Side Includes) and/or the PHP include command. You can find information on how to use both of these on Google. Share this post Link to post Share on other sites
BooZker 0 Report post Posted June 28, 2006 What should i look for though on google? Share this post Link to post Share on other sites
jlhaslip 4 Report post Posted June 29, 2006 try w3cschools.com for information about php includes. Or php.net might be a better source..Then maybe you could have two Headers. One "include" with the Forum Button and one without. Then you "include" the correct Header on each page you build, although it might be simpler to just have the Button on every page. IMHO. Share this post Link to post Share on other sites
Paul 0 Report post Posted June 29, 2006 (edited) I came accross this problem a few years ago (when I did not use PHP for websites).  Here is a solution: FIRST, MAKE A BACKUP OF ALL the files you are going to use **VERY IMPORTANT**rename all you files to .php (using a mass file renamer) download this mass replace tool from <a href="http://forums.xisto.com/no_longer_exists/; target="_blank">http://forums.xisto.com/no_longer_exists/;Now, copy the header code of your website <tr>  <td><img src="images/header.jpg" alt="logo" width="798" height="238" border="0" usemap="#Map" /></td> </tr> <tr> <td><img src="images/AK-tutTemplate02_05.jpg" alt="nav bar" width="21" height="28" /><a href="home.html" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('Image14','','images/home2.jpg',1)"><img src="images/home.jpg" name="Image14" width="58" height="28" border="0" id="Image14" /></a><img src="images/AK-tutTemplate02_07.jpg" alt="nav bar" width="100" height="28" /><a href="videos.html" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('Image13','','images/videos2.jpg',1)"><img src="images/videos.jpg" name="Image13" width="58" height="28" border="0" id="Image13" /></a><img src="images/AK-tutTemplate02_09.jpg" alt="nav bar" width="102" height="28" /><a href="pictures.html" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('Image15','','images/pictures2.jpg',1)"><img src="images/pictures.jpg" name="Image15" width="58" height="28" border="0" id="Image15" /></a><img src="images/AK-tutTemplate02_11.jpg" alt="Nav bar" width="97" height="28" /><a href="downloads.html" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('Image16','','images/downloads2.jpg',1)"><img src="images/downloads.jpg" name="Image16" width="98" height="28" border="0" id="Image16" /></a><img src="images/AK-tutTemplate02_13.jpg" alt="nav bar" width="89" height="28" /><a href="contactus.html" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('Image17','','images/contactus2.jpg',1)"><img src="images/contactus.jpg" name="Image17" width="96" height="28" border="0" id="Image17" /></a><img src="images/AK-tutTemplate02_15.jpg" alt="nav bar" width="21" height="28" /></td> </tr> and paste it in a text file (notepad)Now open the replace utility from step 2There are four fields in this utility: Base Path, Find, Replace, and extentionsUnder base path, browse to the location of all your site filesUnder find, paste the new header code (with the forums link)under extentions enter 'php'And for the replace field, enter <?php include("http://ojproductions.net/inc/header.php"); ?> Now, create a file called header.php and paste the NEW header code in it. And upload this file to a folder called 'inc'Now go back to the replace utility, and find '.html' and replace with '.php' (Since we have changed file extentions, we will need to change internal links.)Upload all the files to your server and it should work fineI reccomend creating a separate footer and header file and including them in the templates. This will make it simpler to edit the template and links  If you need any help PM me Edited June 29, 2006 by Paul (see edit history) Share this post Link to post Share on other sites
BooZker 0 Report post Posted June 30, 2006 I came accross this problem a few years ago (when I did not use PHP for websites). Here is a solution:FIRST, MAKE A BACKUP OF ALL the files you are going to use **VERY IMPORTANT**rename all you files to .php (using a mass file renamer) download this mass replace tool from <a href="http://forums.xisto.com/no_longer_exists/; target="_blank">http://forums.xisto.com/no_longer_exists/;Now, copy the header code of your website QUOTE<tr><td><img src="images/header.jpg" alt="logo" width="798" height="238" border="0" usemap="#Map" /></td></tr><tr><td><img src="images/AK-tutTemplate02_05.jpg" alt="nav bar" width="21" height="28" /><a href="home.html" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('Image14','','images/home2.jpg',1)"><img src="images/home.jpg" name="Image14" width="58" height="28" border="0" id="Image14" /></a><img src="images/AK-tutTemplate02_07.jpg" alt="nav bar" width="100" height="28" /><a href="videos.html" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('Image13','','images/videos2.jpg',1)"><img src="images/videos.jpg" name="Image13" width="58" height="28" border="0" id="Image13" /></a><img src="images/AK-tutTemplate02_09.jpg" alt="nav bar" width="102" height="28" /><a href="pictures.html" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('Image15','','images/pictures2.jpg',1)"><img src="images/pictures.jpg" name="Image15" width="58" height="28" border="0" id="Image15" /></a><img src="images/AK-tutTemplate02_11.jpg" alt="Nav bar" width="97" height="28" /><a href="downloads.html" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('Image16','','images/downloads2.jpg',1)"><img src="images/downloads.jpg" name="Image16" width="98" height="28" border="0" id="Image16" /></a><img src="images/AK-tutTemplate02_13.jpg" alt="nav bar" width="89" height="28" /><a href="contactus.html" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('Image17','','images/contactus2.jpg',1)"><img src="images/contactus.jpg" name="Image17" width="96" height="28" border="0" id="Image17" /></a><img src="images/AK-tutTemplate02_15.jpg" alt="nav bar" width="21" height="28" /></td></tr>and paste it in a text file (notepad)Now open the replace utility from step 2There are four fields in this utility: Base Path, Find, Replace, and extentionsUnder base path, browse to the location of all your site filesUnder find, paste the new header code (with the forums link)under extentions enter 'php'And for the replace field, enter CODE<?php include("http://www.ojproductions.net/inc/header.php;); ?>Now, create a file called header.php and paste the NEW header code in it. And upload this file to a folder called 'inc'Now go back to the replace utility, and find '.html' and replace with '.php' (Since we have changed file extentions, we will need to change internal links.)Upload all the files to your server and it should work fineI reccomend creating a separate footer and header file and including them in the templates. This will make it simpler to edit the template and links If you need any help PM me I have done this multiple times and i can't get it to work. I have created the file and folder for the header. I have pasted the NEW header in the 'find' section and in the PHP file in the 'inc' folder, but it never turns out right. here is what it says the last time i did it> File: C:\Documents and Settings\Oscar\My Documents\O&J Productions BETA\inc\header.php [1 change]Finished. Time taken: <1s659 files searched.1 replacements made.1 files updated.No changes made. That was only a test run.--------------------------- Share this post Link to post Share on other sites
AnGeL KiSS 0 Report post Posted June 30, 2006 I have no idea about these php stuff, but I thought I'd drop by and say you have a nice site. Love how the navigation bars change to a star when you hover over it; it's cute. Share this post Link to post Share on other sites
BooZker 0 Report post Posted June 30, 2006 I have no idea about these php stuff, but I thought I'd drop by and say you have a nice site. Love how the navigation bars change to a star when you hover over it; it's cute.haha its 'cute'! I did that cause our logo its a owl at night. It matches see lol. Thanks for the compliment. And i have been to your site a few times and it's very nice and layout great. Share this post Link to post Share on other sites
