midnitesun 0 Report post Posted April 11, 2006 i am having a problem with my cpanel , sometimes when i move from one directory to another a message window will open and it says that this site contains both secure and non secure information and whether i wish to continue , whether i choose yes or no or even close the window some part og the page i wish to see will not be dispalyed ,it gets so annoying sometimes because i have to satart again whatever i had been doing upto that point of time ,also if it happens once it keeps on recurring very often ,i'm wondering why this should happen ,is it a problem with my browser ? i ues ie6 , and i dont have any kind of firewalls enabled on my system ,so i am hoping some one her can help me out with this ?? i guess i may not be the only one who had experienced this but it sure is awful and time consuming , i would appreciate any kind of help Share this post Link to post Share on other sites
jlhaslip 4 Report post Posted April 11, 2006 It is a Browser setting I believe. Nothing to do with the Cpanel. Look for a setting in your preferences that asks about warnings when you access non-secure Internet pages. I forget the exact words and I don't use IE, so I don't have the actual phrase, but it should be under your security settings, I think. Share this post Link to post Share on other sites
mayank 2 Report post Posted April 12, 2006 Well, as jlhaslip said that it is most likely the browser problem and it seems to be no problem with Cpanel. I'll suggest you one thing here..as you are using IE 6 either restore its setting in the internet options or try to use another browser and then access cpanel with that. Share this post Link to post Share on other sites
midnitesun 0 Report post Posted April 13, 2006 thank you guys ,it seems to have worked Share this post Link to post Share on other sites
BuffaloHelp 24 Report post Posted April 13, 2006 Topic resolved, thread closed. Share this post Link to post Share on other sites
