BOAW 0 Report post Posted February 12, 2006 when i go download a bunch of fonts where do i install them??? i want to use them for my adobe photoshop....pls help i screwed up the last time i tryed heh Share this post Link to post Share on other sites
sxyloverboy 0 Report post Posted February 12, 2006 you have to put them in the C:\windows\fonts\ folder and they will install automaticly. then you can open photoshop or restart it if itsd alrady open and use them from there Share this post Link to post Share on other sites
BOAW 0 Report post Posted February 12, 2006 hmmm u sure....cuz ive tryed that n it didnt work...but there is another folder...its C:\program files\common files\abode\fonts wut about that one? Share this post Link to post Share on other sites
Ao)K-General 0 Report post Posted February 12, 2006 Try it. I don't for sure but try it. It might work. Share this post Link to post Share on other sites
serenity 0 Report post Posted February 12, 2006 well yu download the font and save them in to ur section then unzip it and take the font and copy it into your fonts folder.. this can be found using the control panel. if you want to use them immediately yu must close the photoshop yu have open (if yu do anyway) and open it up again and there yu are the font should already be there Share this post Link to post Share on other sites
BOAW 0 Report post Posted February 12, 2006 yeah i cant use the control panel theres nothing in it about fonts heh...man..i got it workin before...n i forgot which fonts file i install my fonts in to get my photoshop to work...but neways yeah my fonts files is pretty messed up...i got some things in it thats not supposed to b in there and for some reason i cant even remove them...stinks Share this post Link to post Share on other sites
