kvarnerexpress
Need Help To Convert Code To Delphi
. any help is appreciated.
the code is supposed to give the index of elements in an array with a maxSum for any combination of elements in the array while the maxsum is still less than an allowedMax. See the example at the end of code.
function maximum_subset_sum ($max, $candidate_array) {$working_array = array();while ($next = each($candidate_array)) {$candidate = $next['value'];$sums_to_date = array_keys($working_array);while ($marked_sum = each($sums_to_date)) {$known_sum = $marked_sum['value'];$possibly_new = $known_sum + $candidate;if(($possibly_new <= $max) &&!IsSet($working_array[$possibly_new])){$working_array[$possibly_new] = $candidate;}}if(($candidate <= $max) &&!IsSet($working_array[$candidate])){$working_array[$candidate] = $candidate;}}$max_sum = max(array_keys($working_array));$return_array = array($working_array[$max_sum]);while ($max_sum != $working_array[$max_sum]) {$max_sum = $max_sum - $working_array[$max_sum];array_push($return_array, $working_array[$max_sum]);}return($return_array);}// example use$best_sum = maximum_subset_sum(40, array(39,23,19,14,9,5,3,2,1));print("Largest sum is " . array_pop($best_sum));while ($value = array_pop($best_sum)) {print(" + $value");} // will print "Best sum is 23 + 14 + 3"
