Hiaito
A Bit Of Help
I've looked everywhere, and tried making one myself. No luck. I need a spell checker script for forums that can run on the forums without using ActiveX, or Word. Please help, i'm begging.
What forum are you using? IPB, phpbb? and have you looked at their support site to see if the spell check mod is available?
You can't put scripts in InvisionFree, host your own phpbb if you can! You're a hosted Xisto member aren't you, so why use InvisionFree when you could host your own forum! (Migration can be hard though)
well the only real problem hosting a forum is that once you get enough members and have thousands of post then your bw will be used up quicker. Though i have my doubts with invisionfree though cause i see alot of sites use skins that need graphics to be loaded up and you can do some editing to it as well.
