saga
Php And Mysql Problem Need a little help
hi..i'm new in php and mysql... here is my problem....$sql = "SELECT COUNT(*) FROM messages WHERE _parent={$row['_id']}";after sending the query above i dont know how to fetch the actual rows counted..i tried using the mysql_fetch_array() and mysql_fetch_row() function but it didnt work...actually the only function i know that fetches results from sql queries is mysql_fetch_array()...so what function or code i need to have the result from the query which uses COUNT?
Just setting that text string as a variable won't do anything. Put this code after the $sql variable:
mysql_query($sql);
If you want to count the number of rows then use the mysql_num_rows() function. If its fields you're after then use the mysql_num_fields() function.
Hope this helps you.
mysql_query($sql);
191780[/snapback]
of course i query first the $sql variable with mysql_query($sql)..
anyway just a follow up question..
what function parameters shoudl i pass to mysql_num_rows() to be able to get the row count of let say for example WHERE sex = 'male'.. something like that..
what i realy need is not all the row count of a single table but certain rows that contains certain data...
for the meantime i am using ths code to be able to know the number of rows which has a certain data...
while($row = mysql_fetch_array($result))        $count++;
but this kind of approach will take a lot of processing and space in the server.. becuase if the table contains a thousand rows then it will load to memory all those information which is not necesary..
i still need an alternative to this problem.. if there is any.. thnks..
Your problem is your SELECT statement. To SELECT the rows, you need to remove the COUNT() parameter like this.
$sql = "SELECT * FROM messages WHERE _parent={$row['_id']}";
Then to return the actual rows and the count of the rows you need statements something like this, assuming you have 3 fields in each row.
<table><?php $result = mysql_query($sql); $numrows = mysql_num_rows($result); while($row = mysql_fetch_array($result)){echo "<tr><td>$row[field1]</td><td>$row[field2]</td><td>$row[field3]</td></tr>";} ?></table>
The variable '$numrows' will return the count of rows returned by your SELECT statement.
Hope that helps. :huh:
The mysql_num_rows() function returns the number of rows returned from the last query executed, as has been mentioned. Any easy approach would simply be:
mysql_num_rows(mysql_query('SELECT blah FROM blah WHERE sex = "male"'));
When modifying data in a table, the mysql_affected_rows() function returns the number of rows affected by that query (eg. mysql_query('DELETE FROM blah LIMIT 2'); mysql_affected_rows() = 2).
I agree with Spectre allthough he made 1 mistake...mysql_num_rows() returns the result of the "specified" result (no not query) ..so once you executes your query you can use $numerofrows = mysql_num_rows($result); yo make the variable $numerofrows contain an Integer with the rowcount...
hi, saga
overall I have read whole thread, and have this summary if you wish to
1.) only wanted the no. of records(rows) with a sub-set of all records.
you can do this as following, let's say we have a table (table1) with 3 fields:
id, role, groups, then:
k:\mysql\bin>mysql<enter>mysql> show tables;+--------------------+| Tables_in_test_db2 |+--------------------+| table1             |+--------------------+1 row in set (0.00 sec)mysql> select * from table1;+----+------+--------+| id | role | groups |+----+------+--------+|  1 |    0 |      0 ||  2 |    1 |      0 ||  3 |    5 |      0 |+----+------+--------+3 rows in set (0.00 sec)mysql> select count(*) from table1 where role=0;+----------+| count(*) |+----------+|        1 |+----------+1 row in set (0.00 sec)mysql> select count(*) from table1 where groups=0;+----------+| count(*) |+----------+|        3 |+----------+1 row in set (0.00 sec)
as you can see the result that return a value(1, 3 above) with a field named (count(*)). then, you can use :
a.) $row = mysql_fetch_array($result)
b.) $numrow = $row[0];
in fact, you can use $row = mysql_fetch_row($result) also, but that required you modify the sql statement, you can have a reference to mysql mannual
2.) as other forum members stated, you use:
$roleid = 0;
$sql = "SELECT * FROM messages WHERE role=$roleid";
$rownum = mysql_num_rows($result);
$row = mysql_fetch_row($result) ==> for get row
- hope this help
- Eric
