Static_Fury
Trouble Using Ftp help pleas
I am a complete noob when it come to FTP and Xisto, or any professional web host. I know how to upload the files. but then idk how to get my pages to display. They are there. Then i dont understand the concept of multiple FTP accounts.... I could use some really major help.
First, some questions:
What FTP program do you use?
Are you certain you use the correct login info?
Where do you upload your files to?
What extension do you use for your files? (.htm .php .asp)
What port are you connecting to?
These are just a few questions that, if answered, should help all of us to help you on your way.
1+2: Basically, with every ftp program you use, you have to provide a username, password and port, in the case of Trap 17, your username is your cPanel username and pass is cPanel pass, port i cant remember
if you answered questions 1 and 2, you have to know where to upload your files to, if you connected correctly you should be in your www folder, this is not the place to upload your files to, browse through your WWW and go to your public_html in there you upload your files, if, for example, you upload index.htm to your public_html, the correct address to surf to is:
Hope this helps..
ZileZillayes i am useing the correct login infoWhere do you upload your files to? i think this might be my problem....at first i loaded the whole file so yeah it was a new one.....i was using .php...for a template to just messaround and get the hang of it,What port are you connecting to? 21and i am using Xisto service
Port 21 is correct and if you can see some folders you got your login info correct.If you get to the 'root' of your FTP account (keep clicking the Folder Up button until you can't any more) you should see some folders. Among them should be two called 'public_html' and 'www'. You need to upload your web pages to one of those folders (one is a mirror of the other, so it doesn't matter which), and make sure that you have a file called index.htm or .html or .php etc.Tell us if that helps.
im so frustraighted......i cannot get ANYTHING TO WORK! I feel so so mad.....im so lost, i have spent the last 2 months learning html and i get stumped my my cPanel......Can some add me on a messenger i have all but icq, if not well then i am done with web design all together
Hello please dont use any software just use any Browser right now use IE .
1) write in browser ftp.domain-name if your domain point to your exact server otherwise use IP (server IP)
2) go to File --> Click on Login As
3) enter your username and password
4)You can see root folder of your domain then if you have Window Server hosting then go "wwwroot" and Linux Server Hosting then go to "Public_html" folder
5) Just copy paste your file(html,asp,php...) in wwwroot or public_html. (CARE-- Not copy file in Zip content or any compressed file )
