shadowdemon
Phpbb Installation Problem In Fantastico
Install phpBB2(2/3)
The installation can not be completed:
- You cannot install more than one script in the root directory of a domain.
Click on the browser's Back button to fix reported errors.
how do i fix this
186443[/snapback]
If you already have installed a script to your main directory then you are not going to beable to add the forum there. If you have decided that you want your main url to be the forum then you should remove the other script you installed. But if you have not installed any scripts to your main directory then sometimes the only thing you need to do it delete the index placeholder file and then it will install. If you want to keep the page you already have on your main url then take the suggestion above and add a folder called forums or something like that and install there. :P
problem resolved. closing thread...
Guest
