epox
Help With A Css Design code optimization
hello there!, i need somebody tell me how to put a scrollbar into my divs or tables, and how to delete the h3 cellpadding or how to bold a text with css.
thanks a lot! -_-
Scrollbar:
<div style="overflow: auto"></div><td style="overflow: auto"></td>
H3:
<style>h3 {padding: 0px}</style>
Bold:
<style>.bold {font-weight: bold}</style><span class="bold">Bolded Text</span>
That should take care of it.
H3:
You might also need to set your margin to 0 as well. Also, don't need to specify px (or em or %) if the value is just 0.
As far as bolding text goes, it depends why you're boldening it. If you're boldening a whole paragraph, then you'd use the method Truefusion provided, but if you're only boldening a few words or a phrase for emphasis, you're better off using <strong>your words here</strong>. It will look the same on screen, but it means more for people using screen readers and to search engines (ie is given higher importance).
thanks truefusion, all that is useful,but with h3 i want to remove all spaces from the layout(padding, margins) and i put padding:0px, and margin:0px, but it is not working, what is wrong?thanks again!
thanks again!
173226[/snapback]
by the looks of your coding, it appears
truefusion forgot to place in the ";" (semicolon) and you followed suit, resulting in CSS that cannot be read. Remeber to place a semicolon after all CSS declarations.
padding:0px;margin:0px;
The problem may be another thing. It's best if you showed us the code.
hth,
whyme
Edited by whyme (see edit history)
You really don't even need to use h3 tags if you are using css. make a heading class like this
.heading {font-size: 18px;}
or some variation thereof. Then you can call on that with a div tag or any other tag for that matter. One major benefit of doing it this way is that you know how big your text will be in every single browser. h3 tells the browser to figure out how big the font should be.
One thing you might need to do if you are putting this inline is make it float:left so that it doesn't go to it's own line.
hope this helps
hope this helps
191689[/snapback]
I think the use of h1, h2, h3... is the best way to make a coherent structure that will explain itself even without css, which means that will be legible for screen readers... So you better markup your code right and you would help make the web easier for everybody :huh:
Also
thanks again!
I think you can take out the measurement unit (px) from your code... so it will be like this:
css:h3 {margin:0;padding0;}
Hope it helps
Notice from BuffaloHELP:
Edited as reported.
Edited by BuffaloHELP (see edit history)
That's exactly right. Why would you create a class for a tag that already exists, helps define the type of content and is preferred by search engines?
Not if you specify the size for the h3. You can specify the size for any HTML element, you don't have to accept the default size that a browser sets. If you wanted to, you could have your h1, h2, h3 etc. all the same size simply by doing:
h1, h2, h3 { font-size: 200%; }
