switch
Edit Option For Posts adding an option to edit past posts
hii was just wondering if you could maybe add an 'edit' button to the bottom of each post. this would be useful, as just recently i was posting in the warcraft III topic in the gaming/rts subforum and i forgot to say something and so had to post twice.maybe just make it so that if someone has already posted after your post it is uneditable, but until that happens you are free to change it.thanks for considering! :D
some times i always got the problem of typing wrong words or bad words.then i should edit it.but i can not edit.i think your suggestion is good. i supported you.
Guest
