M.A.S.T.E.R. 0 Report post Posted April 26, 2005 I am trying to get a file from a friend on MSN messanger, but somewhere I have a hidden firewall, so I can't get files that way. So, I asked my friend to try sending it through his hotmail account. But, according to Hotmail, it has a unhealable virus, but he has now scanned it with about 5 scanners. And all of them come up nothing, can I have some help? Share this post Link to post Share on other sites
no9t9 0 Report post Posted April 26, 2005 why don't you use a different email address? Your "hidden" firewall is likely in your router. You could directly attach your internet connection to your computer while you transfer the file over MSN messenger. The easiest way is to use another email. Don't you have more than just hotmail?Gmail is the best right now. Or you can use your ISP email. If you need a gmail invite, just PM me. I have tons. Share this post Link to post Share on other sites
R0boT39 0 Report post Posted April 26, 2005 It once happened to me when i was trying to send an attachment through hotmail it said it had a virus, and i tried again, and then it uploaded successfully, if this doesnt work for you, why not send it trhough another type of messenger like AIM, or if your friend is hosted somewere, he can allways upload the file, or if you are hosted you can mek him a subdomain temporarily, there are many other ways to do it, there are some, hope it helps! Share this post Link to post Share on other sites
M.A.S.T.E.R. 0 Report post Posted April 27, 2005 Ok, thank you VERY much for your suggestions. I decided to do what no9t9 said, I unplugged the router, and sent it directly. Thank you both again! Share this post Link to post Share on other sites
Odyssey 0 Report post Posted May 2, 2005 There probably is a port that you open up to allow transfers, I forget what one exactly, but just Google it, and it should tell you. I had the same problems, and since I opened it, everything seems to work well. Share this post Link to post Share on other sites
