Dayzed
Mysql Database Help need help with MySQL databases...skip to page three
Try this, make sure you set the variables.
Before you weren't actually telling the mysql server anything.
<?php$_CONFIG['mbname']    = '';    // Giga Pass$_CONFIG['mbsurl']     = '';    // [url=http://gigapass.trap17.com]http://gigapass.trap17.com[/url]$_CONFIG['dbhost']    = '';    // Xisto.com$_CONFIG['homepage']   = '';    // [url=http://gigapass.trap17.com]http://gigapass.trap17.com[/url]$_CONFIG['legal_tags'] = 'b|i'; // HTML tags allowed in messages. You can only add tags that have no attributes./////// Set these variables:$_MYSQL['dbhost']      = '';    // localhost$_MYSQL['dbuser']      = '';    // dayzed_ejashby$_MYSQL['dbpass']      = '';    // (I put the password for dayzed_ejashby here)$_MYSQL['dbname']      = '';    // dayzed_SQLdatabase//// User level definitions//define('Inactive', 0);define('Warned', 1);define('Mutie', 12);define('Rookie', 15);define('Veteran', 18);define('Idol', 30);define('Moderator', 52);define('Administrator', 60);//// Include money (Coins) configuration. Go edit that file.//require 'mny_config.php';$db = @mysql_connect($_MYSQL['dbhost'], $_MYSQL['dbuser'], $_MYSQL['dbpass'])or die("<b>Error:</b> Failed to connect to database host: {$_MYSQL['dbhost']}<br />       <b>Possible Solution:</b> Check if the database host name, user name and password are defined       correctly in the config.inc.php file.<br />       <b>MySQL says:</b> ". mysql_error());@mysql_select_db($_MYSQL['dbname'], $db)or die("<b>Error:</b> Failed to select database: {$_MYSQL['dbname']}<br />       <b>Possible Solution:</b> Check if the database is set up and the database name       defined in the config.inc.php file is correct.<br />       <b>MySQL says:</b> ". mysql_error());?>
No, the "//" means what ever is after it is a comment but you should probably set thoose variables like this:
$_CONFIG['mbname']    = 'Giga Pass';    // Giga Pass$_CONFIG['mbsurl']     = 'http://gigapass.trap17.com';    // [url=http://gigapass.trap17.com]http://gigapass.trap17.com[/url]$_CONFIG['dbhost']    = 'Xisto.com';    // Xisto.com$_CONFIG['homepage']   = 'http://gigapass.trap17.com';    // [url=http://gigapass.trap17.com]http://gigapass.trap17.com[/url]$_CONFIG['legal_tags'] = 'b|i'; // HTML tags allowed in messages. You can only add tags that have no attributes.
Or use whatever values you want.
$_CONFIG['mbname']    = 'Giga Pass';    // Giga Pass$_CONFIG['mbsurl']     = 'http://gigapass.trap17.com';    // [url=http://gigapass.trap17.com]http://gigapass.trap17.com[/url]$_CONFIG['dbhost']    = 'Xisto.com';    // Xisto.com$_CONFIG['homepage']   = 'http://gigapass.trap17.com';    // [url=http://gigapass.trap17.com]http://gigapass.trap17.com[/url]$_CONFIG['legal_tags'] = 'b|i'; // HTML tags allowed in messages. You can only add tags that have no attributes./////// Set these variables:$_MYSQL['dbhost']      = '';    // localhost$_MYSQL['dbuser']      = '';    // dayzed_ejashby$_MYSQL['dbpass']      = '';    // (I put the password for dayzed_ejashby here)$_MYSQL['dbname']      = '';    // dayzed_SQLdatabase//// User level definitions//define('Inactive', 0);define('Warned', 1);define('Mutie', 12);define('Rookie', 15);define('Veteran', 18);define('Idol', 30);define('Moderator', 52);define('Administrator', 60);//// Include money (Coins) configuration. Go edit that file.//require 'mny_config.php';$db = @mysql_connect($_MYSQL['dbhost'], $_MYSQL['dbuser'], $_MYSQL['dbpass'])or die("<b>Error:</b> Failed to connect to database host: {$_MYSQL['dbhost']}<br />      <b>Possible Solution:</b> Check if the database host name, user name and password are defined      correctly in the config.inc.php file.<br />      <b>MySQL says:</b> ". mysql_error());@mysql_select_db($_MYSQL['dbname'], $db)or die("<b>Error:</b> Failed to select database: {$_MYSQL['dbname']}<br />      <b>Possible Solution:</b> Check if the database is set up and the database name      defined in the config.inc.php file is correct.<br />      <b>MySQL says:</b> ". mysql_error());?>
So the code would be like that?
<?php$_CONFIG['mbname']    = 'Giga Pass';    // Giga Pass$_CONFIG['mbsurl']     = 'http://gigapass.trap17.com';    // [url=http://gigapass.trap17.com]http://gigapass.trap17.com[/url]$_CONFIG['dbhost']    = 'Xisto.com';    // Xisto.com$_CONFIG['homepage']   = 'http://gigapass.trap17.com';    // [url=http://gigapass.trap17.com]http://gigapass.trap17.com[/url]$_CONFIG['legal_tags'] = 'b|i'; // HTML tags allowed in messages. You can only add tags that have no attributes./////// Set these variables://////////THESE MUST BE SET CORRECTLY!$_MYSQL['dbhost']      = 'localhost';    // localhost$_MYSQL['dbuser']      = 'dayzed_ejashby';    // dayzed_ejashby$_MYSQL['dbpass']      = '';    // (I put the password for dayzed_ejashby here)$_MYSQL['dbname']      = 'dayzed_SQLdatabase';    // dayzed_SQLdatabase//// User level definitions//define('Inactive', 0);define('Warned', 1);define('Mutie', 12);define('Rookie', 15);define('Veteran', 18);define('Idol', 30);define('Moderator', 52);define('Administrator', 60);//// Include money (Coins) configuration. Go edit that file.//require 'mny_config.php';$db = @mysql_connect($_MYSQL['dbhost'], $_MYSQL['dbuser'], $_MYSQL['dbpass'])or die("<b>Error:</b> Failed to connect to database host: {$_MYSQL['dbhost']}<br />     <b>Possible Solution:</b> Check if the database host name, user name and password are defined     correctly in the config.inc.php file.<br />     <b>MySQL says:</b> ". mysql_error());@mysql_select_db($_MYSQL['dbname'], $db)or die("<b>Error:</b> Failed to select database: {$_MYSQL['dbname']}<br />     <b>Possible Solution:</b> Check if the database is set up and the database name     defined in the config.inc.php file is correct.<br />     <b>MySQL says:</b> ". mysql_error());?>
Try this, but make sure the variables are set properly.
It works! YAY! Now, the header is messed up... It says in line 261.
<?phpsession_cache_limiter('private, must-revalidate');session_name('sid');session_start();$_PAGE['start_time'] = getmicrotime();//// Unset globals//$methods = array('_POST', '_GET', '_COOKIE', '_FILES');isset($_SESSION) ? $methods[] = '_SESSION' : '';foreach ($methods as $method){    foreach ($$method as $var_name => $var_value)    {        unset($$var_name);    }}$_GET['board']   = isset($_GET['board'])   ? intval($_GET['board'])   : null;$_GET['topic']   = isset($_GET['topic'])   ? intval($_GET['topic'])   : null;$_GET['message'] = isset($_GET['message']) ? intval($_GET['message']) : null;$_GET['user']    = isset($_GET['user'])    ? intval($_GET['user'])    : null;    //// User Authentication Function//function auth($username, $password) {  $result = mysql_query("SELECT username FROM users WHERE username = '$username' AND userpass = '$password'");  return mysql_num_rows($result) != 0 ? mysql_result($result, 0) : null;}//// SQL Field Fetching Function//function get_field($field, $tbl_name, $condition = 1){  $result = mysql_query("SELECT $field FROM $tbl_name WHERE $condition");  return @mysql_result($result, 0);}//// IP Fetching Function//function fetch_ip() {  $ip = isset($_SERVER['HTTP_X_FORWARDED_FOR']) ? $_SERVER['HTTP_X_FORWARDED_FOR'] : $_SERVER['REMOTE_ADDR'];  if (strpos($ip, ','))  {    $ip = explode(',', $ip);    $ip = trim($ip[0]);  }  return $ip;}//// Get Microtime//function getmicrotime() {   list($usec, $sec) = explode(' ', microtime());   return ((float)$usec + (float)$sec); } function navigator($title, $col = 2, $bor = 1, $spc = 0, $info = 1, $other_links = null, $style = null) {  global $q_string, $userlevelm;  if (isset($userlevelm))  {    ?>    <table border="<?= $bor ?>" cellspacing="<?= $spc ?>" width="100%"<?= $style ?>>    <tr><td align="center" colspan="<?= $col ?>"><font size="6"><b><?= $title ?></b></font></td></tr>    <tr><td align="center" colspan="<?= $col ?>" class="b"><i>Return to: <a class="menu" href="index.php">Board List</a>     <?php    if (isset($_GET['board']))    {       ?> | <a class="menu" href="gentopic.php?board=<?= $_GET['board'] ?>">Topic List</a><?php    }    if (isset($_GET['topic']))    {      ?> | <a class="menu" href="genmessage.php<?= $q_string['a'] ?>">Message List</a><?php    }    if ($info == 1)    {      ?> | <a class="menu" href="user.php<?= $q_string['a'] ?>">User Info Page</a><?php    }    if (is_array($other_links))    {      foreach ($other_links as $href => $link_title)      {        $href = explode('|', $href);        if ($href[1] == '' || $userlevelm >= $href[1])        {          ?> | <a class="menu" href="<?= $href[0], $q_string['a'] ?>"><?= $link_title ?></a><?php        }      }    }    if ($userlevelm >= 52)    {      ?> | <a class="menu" href="cpanel.php<?= $q_string['a'] ?>">Control Panel</a><?php    }    ?>    </i></td></tr>    <?php  }  else  {    ?>    <table border="<?= $bor ?>" cellspacing="<?= $spc ?>" width="100%"<?= $style ?>>    <tr><td align="center" colspan="<?= $col ?>"><font size="6"><b><?= $title ?></b></font></td></tr>    <tr><td align="center" colspan="<?= $col ?>" class="b">    <a class="menu" href="index.php">Board List</a>    | <a class="menu" href="register.php">Register</a>    | <a class="menu" href="login.php">Log In</a>    | <a class="menu" href="help.php">Help</a>     | <a class="menu" href="tos.php">ToS</a></td></tr>    <?php  }}//// Update Counter//mysql_query("UPDATE counters SET count_value=count_value+1 WHERE count_type='boards'");//// IP Banning//if (isset($_COOKIE['zXi7g']))  die;$result = mysql_query('SELECT ip_addr FROM banned_ips');while ($row = mysql_fetch_row($result)){  if (stristr($_SERVER['REMOTE_ADDR'], $row[0]) || stristr($_SERVER['HTTP_REFERER'], $row[0]))  {    setcookie('zXi7g', 'o', time()+92275200);    die;  }}if (stristr($_SERVER['HTTP_USER_AGENT'], 'anon'))  die;//// User Name and Password Retrieval//$uname = isset($_SESSION['username']) ? $_SESSION['username'] : (isset($_COOKIE['uname']) ? $_COOKIE['uname'] : null);$pword = isset($_SESSION['password']) ? $_SESSION['password'] : (isset($_COOKIE['pword']) ? $_COOKIE['pword'] : null);//// Common User Info Retrieval//$row = @mysql_fetch_row(@mysql_query("SELECT userid, level, style, timezone, sidebar FROM users WHERE username='$uname' AND userpass='$pword'"));if (isset($row[0])){  $useridm = $row[0];  $userlevelm = $row[1];  $userstylem = $row[2];  $_PAGE['timezone'] = $row[3]*3600;  $_PAGE['sidebar'] = $row[4];  mysql_query("UPDATE users SET lastsec='".time()."', lastacip='{$_SERVER['REMOTE_ADDR']}', last_page='". htmlspecialchars(preg_replace('#sid=[[:alnum:]]+(\&)*#i', '', $_SERVER['REQUEST_URI']), ENT_QUOTES) ."', user_agent='". htmlspecialchars($_SERVER['HTTP_USER_AGENT'], ENT_QUOTES) ."', real_ip = '". fetch_ip() ."' WHERE userid='$useridm'");}//// Spit It All Out//?><html><head><title><?= $_CONFIG['mbsname'] ?>: <?= $title ?></title><meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1" /><?phpswitch ($userstylem) {  case 'custom':  extract(@mysql_fetch_assoc(mysql_query("SELECT * FROM style WHERE userid='$useridm'")));  echo "<style type=\"text/css\">a:link {color: $n_link; text-decoration: underline}a:visited {color: $n_vlink; text-decoration: underline}a.menu:link {color: $m_link; text-decoration: underline}a.menu:visited {color: $m_vlink; text-decoration: underline}a.menu:hover {color: $m_hlink; text-decoration: underline}a.menu:active {color: $m_alink; text-decoration: underline}body, td {background-color: $main_bg; font-family: $font_face; font-size: 80%;color: $font_color}.a {background-color: $c1_bg; font-size: 95%; color: $c1_fc; font-weight: bold}.b {background-color: $c2_bg; font-size: 95%; color: $c2_fc; font-weight: bold}.c {background-color: $c3_bg}.d {background-color: $c4_bg}.system {background-color: $system_bg}.shade {background-color: $shade_bg}.sidebar {background-color: $sidebar_bg}.large {font-size: 120%; font-weight: bold}.medium {font-size: 90%}.poll_graph {display: block; background-color: $poll_graph; line-height: 25px}</style>\n";  break;  default:  empty($userstylem) ? $userstylem = 1 : '';  $theme_path = mysql_result(mysql_query("SELECT theme_path FROM themes WHERE theme_id = $userstylem"), 0);  echo '<link rel="stylesheet" type="text/css" href="'.$theme_path.'" />' . "\n";}echo $_PAGE['sidebar'] == 1 ? '<link rel="stylesheet" type="text/css" href="styles/margins.css" />' : '';?></head><body><?$_PAGE['sidebar'] == 1 ? include 'sidebar_header.inc.php' : '';if (isset($_GET['message']))  get_field('COUNT(*)', 'messages', "messageid = '{$_GET['message']}'") == 0 ? die('Invalid Message ID') : '';if (isset($_GET['topic']))  get_field('COUNT(*)', 'topics', "topicid = '{$_GET['topic']}' AND board='{$_GET['board']}'") == 0 ? die('Invalid Topic ID') : '';if (isset($_GET['board']))  get_field('COUNT(*)', 'boards', "boardid = '{$_GET['board']}'") == 0 ? die('Invalid Board ID') : '';if (isset($_GET['user']))  get_field('COUNT(*)', 'users', "userid = '{$_GET['user']}'") == 0 ? die('Invalid User ID') : '';if (defined('_FILE_LVL')){  if ($userlevelm < _FILE_LVL)  {    echo '<div align="center"><b><font size="6">Error</font></b></div><br /><div align="left">You have to be at least level <b>'.52.'</b> to view this page. Return to the <a href="javascript:window.history.go(-1)">previous page</a> or the <a href="index.php">general board list</a>.</div>';    include 'footer.inc.php';    exit;  }}if ($userlevelm >= 52){  $result   = mysql_query('SELECT COUNT(*) FROM marked');  $num_msgs = mysql_result($result, 0);  $result  = mysql_query("SELECT COUNT(*) FROM temp_users WHERE act_status = 2");  $num_pend_users = mysql_result($result, 0);  ?>  <span class="d" style="display: block; width: 100%; line-height: 25px; text-align: center"><b>Backlog:</b> <a href="mark_queue.php">Marked Messages</a> - <b><?= $num_msgs ?></b> / <a href="man_act_user.php">Inactive Users</a> - <b><?= $num_pend_users ?></b></span>  <?php}//// Set Common Query String Variables//$q_string_x = '';$q_string_x .= isset($_GET['board']) ? 'board=' . $_GET['board'] : '';$q_string_x .= isset($_GET['topic']) ? '&topic=' . $_GET['topic'] : '';$q_string = array();$q_string['a'] = '';$q_string['b'] = '';if ($q_string_x != ''){  $q_string['a'] = '?' . $q_string_x;  $q_string['b'] = '&' . $q_string_x;}?>
For one, I dont know which is line 261, since I dont know how to count lines with a program. And if I did, I wouldn't know what to do. :\
<?phpsession_cache_limiter('private, must-revalidate');session_name('sid');session_start();$_PAGE['start_time'] = getmicrotime();//// Unset globals//$methods = array('_POST', '_GET', '_COOKIE', '_FILES');isset($_SESSION) ? $methods[] = '_SESSION' : '';foreach ($methods as $method){   foreach ($$method as $var_name => $var_value)   {       unset($$var_name);   }}$_GET['board']   = isset($_GET['board'])   ? intval($_GET['board'])   : null;$_GET['topic']   = isset($_GET['topic'])   ? intval($_GET['topic'])   : null;$_GET['message'] = isset($_GET['message']) ? intval($_GET['message']) : null;$_GET['user']    = isset($_GET['user'])    ? intval($_GET['user'])    : null;    //// User Authentication Function//function auth($username, $password){ $result = mysql_query("SELECT username FROM users WHERE username = '$username' AND userpass = '$password'"); return mysql_num_rows($result) != 0 ? mysql_result($result, 0) : null;}//// SQL Field Fetching Function//function get_field($field, $tbl_name, $condition = 1){ $result = mysql_query("SELECT $field FROM $tbl_name WHERE $condition"); return @mysql_result($result, 0);}//// IP Fetching Function//function fetch_ip(){ $ip = isset($_SERVER['HTTP_X_FORWARDED_FOR']) ? $_SERVER['HTTP_X_FORWARDED_FOR'] : $_SERVER['REMOTE_ADDR']; if (strpos($ip, ',')) {   $ip = explode(',', $ip);   $ip = trim($ip[0]); } return $ip;}//// Get Microtime//function getmicrotime(){ list($usec, $sec) = explode(' ', microtime()); return ((float)$usec + (float)$sec);}function navigator($title, $col = 2, $bor = 1, $spc = 0, $info = 1, $other_links = null, $style = null){ global $q_string, $userlevelm; if (isset($userlevelm)) {   ?>   <table border="<?= $bor ?>" cellspacing="<?= $spc ?>" width="100%"<?= $style ?>>   <tr><td align="center" colspan="<?= $col ?>"><font size="6"><b><?= $title ?></b></font></td></tr>   <tr><td align="center" colspan="<?= $col ?>" class="b"><i>Return to: <a class="menu" href="index.php">Board List</a>   <?php   if (isset($_GET['board']))   {     ?> | <a class="menu" href="gentopic.php?board=<?= $_GET['board'] ?>">Topic List</a><?php   }   if (isset($_GET['topic']))   {     ?> | <a class="menu" href="genmessage.php<?= $q_string['a'] ?>">Message List</a><?php   }   if ($info == 1)   {     ?> | <a class="menu" href="user.php<?= $q_string['a'] ?>">User Info Page</a><?php   }   if (is_array($other_links))   {     foreach ($other_links as $href => $link_title)     {       $href = explode('|', $href);       if ($href[1] == '' || $userlevelm >= $href[1])       {         ?> | <a class="menu" href="<?= $href[0], $q_string['a'] ?>"><?= $link_title ?></a><?php       }     }   }   if ($userlevelm >= 52)   {     ?> | <a class="menu" href="cpanel.php<?= $q_string['a'] ?>">Control Panel</a><?php   }   ?>   </i></td></tr>   <?php } else {   ?>   <table border="<?= $bor ?>" cellspacing="<?= $spc ?>" width="100%"<?= $style ?>>   <tr><td align="center" colspan="<?= $col ?>"><font size="6"><b><?= $title ?></b></font></td></tr>   <tr><td align="center" colspan="<?= $col ?>" class="b">   <a class="menu" href="index.php">Board List</a>   | <a class="menu" href="register.php">Register</a>   | <a class="menu" href="login.php">Log In</a>   | <a class="menu" href="help.php">Help</a>   | <a class="menu" href="tos.php">ToS</a></td></tr>   <?php }}//// Update Counter//mysql_query("UPDATE counters SET count_value=count_value+1 WHERE count_type='boards'");//// IP Banning//if (isset($_COOKIE['zXi7g'])) die;$result = mysql_query('SELECT ip_addr FROM banned_ips');while ($row = mysql_fetch_row($result)){ if (stristr($_SERVER['REMOTE_ADDR'], $row[0]) || stristr($_SERVER['HTTP_REFERER'], $row[0])) {   setcookie('zXi7g', 'o', time()+92275200);   die; }}if (stristr($_SERVER['HTTP_USER_AGENT'], 'anon')) die;//// User Name and Password Retrieval//$uname = isset($_SESSION['username']) ? $_SESSION['username'] : (isset($_COOKIE['uname']) ? $_COOKIE['uname'] : null);$pword = isset($_SESSION['password']) ? $_SESSION['password'] : (isset($_COOKIE['pword']) ? $_COOKIE['pword'] : null);//// Common User Info Retrieval//$row = @mysql_fetch_row(@mysql_query("SELECT userid, level, style, timezone, sidebar FROM users WHERE username='$uname' AND userpass='$pword'"));if (isset($row[0])){ $useridm = $row[0]; $userlevelm = $row[1]; $userstylem = $row[2]; $_PAGE['timezone'] = $row[3]*3600; $_PAGE['sidebar'] = $row[4]; mysql_query("UPDATE users SET lastsec='".time()."', lastacip='{$_SERVER['REMOTE_ADDR']}', last_page='". htmlspecialchars(preg_replace('#sid=[[:alnum:]]+(\&)*#i', '', $_SERVER['REQUEST_URI']), ENT_QUOTES) ."', user_agent='". htmlspecialchars($_SERVER['HTTP_USER_AGENT'], ENT_QUOTES) ."', real_ip = '". fetch_ip() ."' WHERE userid='$useridm'");}//// Spit It All Out//?><html><head><title><?= $_CONFIG['mbsname'] ?>: <?= $title ?></title><meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1" /><?phpswitch ($userstylem){ case 'custom': extract(@mysql_fetch_assoc(mysql_query("SELECT * FROM style WHERE userid='$useridm'"))); echo "<style type=\"text/css\">a:link {color: $n_link; text-decoration: underline}a:visited {color: $n_vlink; text-decoration: underline}a.menu:link {color: $m_link; text-decoration: underline}a.menu:visited {color: $m_vlink; text-decoration: underline}a.menu:hover {color: $m_hlink; text-decoration: underline}a.menu:active {color: $m_alink; text-decoration: underline}body, td {background-color: $main_bg; font-family: $font_face; font-size: 80%;color: $font_color}.a {background-color: $c1_bg; font-size: 95%; color: $c1_fc; font-weight: bold}.b {background-color: $c2_bg; font-size: 95%; color: $c2_fc; font-weight: bold}.c {background-color: $c3_bg}.d {background-color: $c4_bg}.system {background-color: $system_bg}.shade {background-color: $shade_bg}.sidebar {background-color: $sidebar_bg}.large {font-size: 120%; font-weight: bold}.medium {font-size: 90%}.poll_graph {display: block; background-color: $poll_graph; line-height: 25px}</style>\n"; break; default: empty($userstylem) ? $userstylem = 1 : ''; $theme_path = mysql_result(mysql_query("SELECT theme_path FROM themes WHERE theme_id = $userstylem"), 0); echo '<link rel="stylesheet" type="text/css" href="'.$theme_path.'" />' . "\n";}echo $_PAGE['sidebar'] == 1 ? '<link rel="stylesheet" type="text/css" href="styles/margins.css" />' : '';?></head><body><?$_PAGE['sidebar'] == 1 ? include 'sidebar_header.inc.php' : '';if (isset($_GET['message'])) get_field('COUNT(*)', 'messages', "messageid = '{$_GET['message']}'") == 0 ? die('Invalid Message ID') : '';if (isset($_GET['topic'])) get_field('COUNT(*)', 'topics', "topicid = '{$_GET['topic']}' AND board='{$_GET['board']}'") == 0 ? die('Invalid Topic ID') : '';if (isset($_GET['board'])) get_field('COUNT(*)', 'boards', "boardid = '{$_GET['board']}'") == 0 ? die('Invalid Board ID') : '';if (isset($_GET['user'])) get_field('COUNT(*)', 'users', "userid = '{$_GET['user']}'") == 0 ? die('Invalid User ID') : '';if (defined('_FILE_LVL')){ if ($userlevelm < _FILE_LVL) {   echo '<div align="center"><b><font size="6">Error</font></b></div><br /><div align="left">You have to be at least level <b>\'.52.\'</b> to view this page. Return to the <a href="javascript:window.history.go(-1)">previous page</a> or the <a href="index.php">general board list</a>.</div>';   include 'footer.inc.php';   exit; }}if ($userlevelm >= 52){ $result   = mysql_query('SELECT COUNT(*) FROM marked'); $num_msgs = mysql_result($result, 0); $result  = mysql_query("SELECT COUNT(*) FROM temp_users WHERE act_status = 2"); $num_pend_users = mysql_result($result, 0); ?> <span class="d" style="display: block; width: 100%; line-height: 25px; text-align: center"><b>Backlog:</b> <a href="mark_queue.php">Marked Messages</a> - <b><?= $num_msgs ?></b> / <a href="man_act_user.php">Inactive Users</a> - <b><?= $num_pend_users ?></b></span> <?php}//// Set Common Query String Variables//$q_string_x = '';$q_string_x .= isset($_GET['board']) ? 'board=' . $_GET['board'] : '';$q_string_x .= isset($_GET['topic']) ? '&topic=' . $_GET['topic'] : '';$q_string = array();$q_string['a'] = '';$q_string['b'] = '';if ($q_string_x != ''){ $q_string['a'] = '?' . $q_string_x; $q_string['b'] = '&' . $q_string_x;}?>[/codeBOX]
This should work, you had put a single quote in the string you were trying to echo.Use notepad, turn off Word wrap, and press ctrl G
There are a couple screwed up:
$result = mysql_query('SELECT ip_addr FROM banned_ips');while ($row = mysql_fetch_row($result)){if (stristr($_SERVER['REMOTE_ADDR'], $row[0]) || stristr($_SERVER['HTTP_REFERER'], $row[0]))
default:empty($userstylem) ? $userstylem = 1 : '';$theme_path = mysql_result(mysql_query("SELECT theme_path FROM themes WHERE theme_id = $userstylem"), 0);
Those are the messed up ones and some lines around them.
You have some text being outputted in your config.inc.php file, you can't have that. ANY white space outside of the php tags is considered output.I'm guessing that in this query "SELECT ip_addr FROM banned_ips" either the table or the field doesn't exist. if it doesn't make it, if it does I don?t know what the problem is.Same thing for "SELECT theme_path FROM themes WHERE theme_id = $userstylem"
Once you upload the files, you have to create a new database for the boards. Then you use the SQL in the SQL file to create all the tables needed for the boards. Then you go into the config.inc.php and edit the database connection variables to the yours. It should look like this:
$_MYSQL['dbhost'] = 'localhost';$_MYSQL['dbuser'] = 'CPANELUSERNAME_DBUSER';$_MYSQL['dbpass'] = 'DBUSERPASS';$_MYSQL['dbname'] = 'CPANELUSERNAME_DBNAME';
