tripletriangle 0 Report post Posted March 22, 2005 Im customizing an Invision Power Board and tried a few skins... I came up with one but would like to change the backroung to a picture I have saved in my computer...I can't seem to find that option, if there is any... Can anyone help me??Thanks! Share this post Link to post Share on other sites
serverph 0 Report post Posted March 22, 2005 you just need to overwrite the default background image with the picture you want to appear as you new background. but you should consider to resize your new background to have the same size configuration as the old one. when done, just upload it to your host with the same filename and extension as the default. Share this post Link to post Share on other sites
