HellFire121
N-Vidia Aladdin TNT-2 Help
hi, well i have a very old aladdin tnt2 and i am having alot of problems with it in graphics and speed, first off it is very slow in games that have minimum specs much lower than my pc, second i have an old copy of UT and all the text/images are garbled if i try to run it in d3d, but in opengl it works... very slowly, all other games will work in d3d as well as opengl.Could anyone suggest the drivers i should use?32mb Aladdin tnt21ghz celeronThanks
ok thanks, this wont stuff up my pc or anything? because it is a beta driver, so i dont know. Do you know if it works?
1064336916[/snapback]
If should work, thats the one i used when i had my TNT2 M64 card. IF not go lower in drivers like don't go pass the 30.xx drivers. Your card won't be optimized for it.
