soleimanian 0 Report post Posted July 18, 2005 Hi i have a problem in capturing videoi have a Sony Digital camera and i use USB port to transfer files and capture movies. i don't have video capture card, or IEEE 1394 port to capture moviequality of captured movies is low.now, please help me how i can increase quality,is it depends to fps(frames per second), Display size, bit rate ?? Share this post Link to post Share on other sites
Moody 0 Report post Posted July 18, 2005 Be sure you camera can handle more bitrate or fps...if he only can do 6 fps, you can't make 10 of them. And is it a photocamera, that is able to make short videos or is it a video camera? Share this post Link to post Share on other sites
LikMeBalleFM 0 Report post Posted July 19, 2005 Try using a "DivX" compression when capturing Share this post Link to post Share on other sites
spacewaste1405241471 0 Report post Posted July 19, 2005 As Moody said, please be sure your camera is able to have high quality video capturing first of all.Secondly, yes, by increasing the fps you'll have better quality, as there will be less 0.0X second gaps between frames, makes it less blurry.But it also involves pixels.Try setting the resolution lower. ^--------But only do that if you don't mind having the video small in the witdh to height ratio.Also, try adjusting the lens.IF none of these work, please specify your exacte camera. Share this post Link to post Share on other sites
saga 0 Report post Posted July 20, 2005 is it a digital videocam or just a camera? Well anyway, if it is just a camera with a feature that could capture videos expect it to be in low quality for generaly they are design in taking stiill pictures. If you want to have a high quality videos you need to have a videocam not a camera. Videocam produces very high quality videos, even more better than the one in DVD movies becuase it is not compresed and has the frame size of 720x400 i guess, its close to that. But you need to have IEEE or firewore port becuase USB can not handle a fast transfer rate like that of the uncompresed digital frames from videocams.. so i hope it clear things up not mess it up for u .. Share this post Link to post Share on other sites
