harriko 0 Report post Posted June 24, 2005 ok at the moment im using invision board supplied by the server. now... im having problems with it.. anyone know how to solve it. i only have really small knowledge of php. thankshttp://forums.xisto.com/no_longer_exists/it may have been the database. i dont know... thanks Share this post Link to post Share on other sites
jipman 0 Report post Posted June 24, 2005 Warning: mysql_connect(): Too many connections in /home/tbaforum/public_html/forum/sources/Drivers/mySQL.php on line 65Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/tbaforum/public_html/forum/sources/Drivers/mySQL.php on line 68ERROR: Cannot find database tbaforum_ivbd1Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/tbaforum/public_html/forum/sources/Drivers/mySQL.php on line 101 Warning: mysql_connect(): Too many connectionsThis means that there were too many connections to the db-server ?? Maybe the server is flooded or something( if it happens everytime)Warning: mysql_select_db() This is because the server can't establish the connection, thus failing to select a databaseWarning: mysql_query(): It can't find the database, so it can't run the query.I suggest trying to check the settings of the ipb installer and / or the settings of the databases in either your cpanel or a phpadmin thingy. Share this post Link to post Share on other sites
WeaponX 0 Report post Posted June 24, 2005 It's most likely the server being overloaded by too many requests. If you know it's not your site that's doing this, and if it happens a lot (with the sql errors), I would contact your webhost and notify them about this. Share this post Link to post Share on other sites
Hercco 0 Report post Posted June 27, 2005 It looks like your host is piece of crap... The page didn't even open for me. And yeah those errors indicate that the server is heavily overloaded. Share this post Link to post Share on other sites
