Jackel 0 Report post Posted June 13, 2005 Ok. On a website, how do you make it so that an image is transparent (see through)? Ive heard something about you can only do it in photoshop. Please help if u know how to. Share this post Link to post Share on other sites
@non 0 Report post Posted June 13, 2005 okay..well the basic file types that support transparency are .gif and .png...there are many others though..i think that gif files are more commonly used on websites.. and by transparent are you talking about making some parts of the picture transparent or the whole picture semi-transparent or what excatly... i tried using 24bit png files on sites and they dont seem to work so well..perhaps im not doing it right though.there are some sites i have seen that look as though they use some type of mask for true mutilevel transparency.. not a clue as to how they do this though it might be something to look into.and you can do it in alot of different programs..not only photoshop. Share this post Link to post Share on other sites
Rudy1405241475 0 Report post Posted June 14, 2005 The most common transparent graphics I have seen is GIF images.Transparency is acquired by using several methods including:1 Using the same color for the background of the graphic as the page back ground color it is placed in.2 Making you graphic background color black and set the transparency to black. Then select save as and set the file as a “GIF89a” in the options tab. Share this post Link to post Share on other sites
SunBlind 0 Report post Posted June 29, 2005 ... Or are you asking about how to make an image seem transparent on the actual page, like with a css filter? Share this post Link to post Share on other sites
runefantasy 0 Report post Posted June 29, 2005 To make it transparent, I use Adobe Photoshop (paint doesn't have transparent ability). You first create a file, make the background 'transparent'. Click ok, design your picture, etc, etc. Save it as a .gif (or .png I think) and put it on a page! When the page changes color, the parts of the picture that you left transparent will be that page's color(therefore transparent) Share this post Link to post Share on other sites
BurntToast 0 Report post Posted July 17, 2005 If the image has a distinctly different background (such as a jpeg with a white background) you can simply use the magic wand tool, then save it as a gif file. If the background isn't very different from the colors of the main image, you can use the extract tool in the filter menu Share this post Link to post Share on other sites
Cj_girl808 0 Report post Posted July 25, 2005 If you are referring to a css filter for making IMAGES on your website appear transparent then here's the code: <style type="text/css">a img{filter:alpha(opacity=50);}</style> That will make all the images on your webpage 50 percent transparent. Of course, you can change the opacity number to your liking, where the lower the number the more transparent the image will be.You can also choose to make the images on your page transparent with mouseover:<style type="text/css">a:hover img{filter:alpha(opacity=50);}</style> Share this post Link to post Share on other sites
