Darren0330 0 Report post Posted June 3, 2005 Anyone out there use Sonar 4?? I could use some help... Share this post Link to post Share on other sites
bigredrosen 0 Report post Posted June 16, 2005 Anyone out there use Sonar 4?? I could use some help...is that the audio/video editing program?zack Share this post Link to post Share on other sites
Neverseen 0 Report post Posted June 17, 2005 Don't know about the video, but it's mostly an audio editing software which is intended for serious musicians and studio engineers. It's fun to use, but beginners may be intimidated at first. Designed to be the heart of a recording environment, SONAR can mix live audio, loops, MIDI, and CD tracks, and the resulting mix can be exported to MP3, WMA or RealAudio. Version 4 adds surround sound mixing and audio track editing. Share this post Link to post Share on other sites
Koel 0 Report post Posted June 29, 2005 I asume you mean CakeWalk Sonar 4. What exactly do you need help with? I use CakeWalk Homestudio, but I know some people who use Cakewalk Sonar. Your best bet is to just read the instructions and keep plaing around with it. Or you could check out their support forums at http://forums.xisto.com/no_longer_exists/ Share this post Link to post Share on other sites
iGuest 3 Report post Posted March 18, 2008 HiHow do I bounce down tracks in order to make more space and improve my processing capacity.-reply by Etienne Share this post Link to post Share on other sites
iGuest 3 Report post Posted April 18, 2008 What Sonar 4 Help I'm using Sonar 4 PE and everytime I record any straight audio it plays back an octave lower than I played it. What's up with my audio? I'm using SoundBlaster 5.1 -question by Jazzy Share this post Link to post Share on other sites
iGuest 3 Report post Posted July 28, 2009 Sonar 4 and reltek sound cardSonar 4 HelpInstalled Sonar 4 It can't play back , because it says to select a MIDI out put. I don't have a MIDI sound card just have reltek HD audio. Any IDEAs. MIke -question by Mike Share this post Link to post Share on other sites
