finaldesign1405241487 0 Report post Posted May 30, 2005 Well, because of my work at design office, I stuck with my exam at colledge. It's an exam of XML. I must make an XML+XSLT compatible web site with 4 pages minimum, of description of how I did it. Now, I do not know much of XML, so if anyone here have some tutorials, ebooks, links that would help me, I would be eternaly gratefull... Share this post Link to post Share on other sites
hazeshow 0 Report post Posted May 31, 2005 Hi, perhaps this will help you: http://www.xml.com/pub/a/98/10/guide0.html If you make a website using XML and XSLT you have to decide where and how the transformation into HTML is done, on the server or in the user's browser. MS Internet Explorer has an own XML-parser and an own way to treat XML/XSLT. Let's say you have am XML-file 'cool.xml' and you want to throw it against the stylesheet 'hot.xsl'. Internet Explorer will show the HTML-result with the following simple code included in an HTML-file: <XML id="source" src="cool.xml"></XML> <XML id="style" src="hot.xsl"></XML> <script FOR="window" EVENT="onload"> xslTarget.innerHTML = source.transformNode(style.XMLDocument); </SCRIPT> <DIV id="xslTarget"></DIV> In this case the transformation takes place in the user's browser and only works with Internet Explorer version 5.5 or higher. I once found this on Microsoft's website, and I think it's pretty cool but as far as I know it does not work with other browsers than IE. If you want to let the transformation take place on the server, you need a server-sided script language like PHP. You can (if you can - I can't) write your own XML-parser in PHP or use the xslt_create()-function. For this XSLT-support has to be enabled (Sablotron). Good luck and fun with your exam! GreetingZ Share this post Link to post Share on other sites
finaldesign1405241487 0 Report post Posted June 1, 2005 If you want to let the transformation take place on the server, you need a server-sided script language like PHP. You can (if you can - I can't) write your own XML-parser in PHP or use the xslt_create()-function. For this XSLT-support has to be enabled (Sablotron). Good luck and fun with your exam! GreetingZ <{POST_SNAPBACK}> Thanks for the reply man, so it means that if I want transformation on the server side, I need to write XML-Parser... Isn't that already written by someone...? Do you know maybe is XSLT-support enabled on Xisto servers? Share this post Link to post Share on other sites
hazeshow 0 Report post Posted June 1, 2005 Yes sure, XML-parser-scripts already exist, but I always found it too hard to implement them in my code. Might be easy for programming natures - but not for me. The Xisto-server DOES support XSLT, see here:http://forums.xisto.com/ But it seems that for the user's website accounts the XSLT support first has to be implemented. I asked for it in the forum and one hour later I had my Sablotron. As I said, I use the xslt_create()-function, it goes like this: <?php $xh = xslt_create(); if ($result = xslt_process($xh, 'cool.xml', 'hot.xsl')) { echo $result; xslt_free($xh); } else { echo "<p>"; echo xslt_error($xh); echo xslt_errno($xh); echo "</p>"; xslt_free($xh); } ?> I'm telling you one thing .... this is sooo cool! GreetingZ Share this post Link to post Share on other sites
finaldesign1405241487 0 Report post Posted June 2, 2005 hey I still need some help with this... Ok I've managed to understand something, and make some xml files... but I dont understand if I make an XML document, then make one XSLT document so I can display properly and nice that XML...Now how can I use CSS in that XSLT document, and apply that CSS on XSLT elements... (if you don't understand exactly what I want I'll put a source Code here...)thanks! Share this post Link to post Share on other sites
hazeshow 0 Report post Posted June 2, 2005 Yes, that's it exactly! You create an XSL-document for displaying your XML-file in HTML. Your XSL-file IS the stylesheet, you could only use CSS INSTEAD of CSS. Here's an example: You need three files: simple.php, simple.xml and simple.xsl. And you need a Server with XSLT-support. (By the way ... they must have rebooted the machines here at Xisto, at the moment my account does not support XSLT) Ok, here comes the Belgian Waffels example: simple.php <?php $xh = xslt_create(); if ($result = xslt_process($xh, 'simple.xml', 'simple.xsl')) { echo $result; xslt_free($xh); } else { echo "<p>"; echo xslt_error($xh); echo xslt_errno($xh); echo "</p>"; xslt_free($xh); } ?> simple.xml <?xml version='1.0'?> <breakfast-menu> <food> <name>Belgian Waffles</name> <price>$5.95</price> <description>Two of our famous Belgian Waffles with plenty of real maple syrup.</description> <calories>650</calories> </food> <food> <name>Strawberry Belgian Waffles</name> <price>$7.95</price> <description>Light Belgian waffles covered with strawberries and whipped cream.</description> <calories>900</calories> </food> <food> <name>Berry-Berry Belgian Waffles</name> <price>$8.95</price> <description>Light Belgian waffles covered with an assortment of fresh berries and whipped cream.</description> <calories>900</calories> </food> <food> <name>French Toast</name> <price>$4.50</price> <description>Thick slices made from our homemade sourdough bread.</description> <calories>600</calories> </food> <food> <name>Homestyle Breakfast</name> <price>$6.95</price> <description>Two eggs, bacon or sausage, toast, and our ever-popular hash browns.</description> <calories>950</calories> simple.xsl <?xml version="1.0"?> <xsl:stylesheet version="1.0" xmlns:xsl="http://forums.xisto.com/no_longer_exists/; <xsl:template match="/"> <HTML> <BODY STYLE="font-family:Arial, helvetica, sans-serif; font-size:12pt; background-color:#EEEEEE"> <xsl:for-each select="breakfast-menu/food"> <DIV STYLE="background-color:teal; color:white; padding:4px"> <SPAN STYLE="font-weight:bold; color:white"><xsl:value-of select="name"/></SPAN> - <xsl:value-of select="price"/> </DIV> <DIV STYLE="margin-left:20px; margin-bottom:1em; font-size:10pt"> <xsl:value-of select="description"/> <SPAN STYLE="font-style:italic"> (<xsl:value-of select="calories"/> calories per serving) </SPAN> </DIV> </xsl:for-each> </BODY> </HTML> </xsl:template> </xsl:stylesheet> Try it out and play with it! Good luck! Share this post Link to post Share on other sites
finaldesign1405241487 0 Report post Posted June 2, 2005 thanks man! I'll try it that way... I hope I'll make what I want... Share this post Link to post Share on other sites
finaldesign1405241487 0 Report post Posted June 20, 2005 hey I passed that exam, you can see what I did at this link:My First XML Share this post Link to post Share on other sites
hazeshow 0 Report post Posted June 20, 2005 Hey ... wow! That XSLT-file must have been hard work! The xsl:for-each select and xsl:value-of select can drive someone crazy ... Looks really good! <congratulation>MY CONGRATULATIONS!</congratulation> Share this post Link to post Share on other sites
finaldesign1405241487 0 Report post Posted June 21, 2005 yeah, well, after few hours of surfing and reading on other forums, I found a solution, In fact it's simple, just what you need to to is follow simple XML rules... I have them written in script of that Exam I took, so if anyone wants to know and learn more, just PM me... Share this post Link to post Share on other sites
