jedipi
Vim Syntax Highlight Problem
I got a problem with vim syntax highlight.When i type "syntax on" in the command mode , the vim return an error "can not open file /usr/share/vim/vim61/syntax/syntax.vim".then I found that I really don't have this file or directory. Because I use vim63 actually. The correct path will be "/usr/share/vim/vim63/syntax/syntax.vim". Am I right??I guess i should edit the path somewhere to solve the problem, but i can't find it.Please help me!! What i should do.Thank you very much!
does the file "/usr/share/vim/vim63/syntax/syntax.vim" exist ?
is so, you ca use a symbolic link.
cd /usr/share/ln -s vim63 vim61
next time an application tries to access " /usr/share/vim/vim61/syntax/syntax.vim" it will be routed, ad filesystem level to " /usr/share/vim/vim63/syntax/syntax.vim"
this is more of a quick solution, a better way may be to find an incorrect config file, and correct it. look for vim config files hidden in you home directory, or in /etc/
Thanks for your help.
yes, "/usr/share/vim/vim63/syntax/syntax.vim" does exist in my system.
Therefore, the command "ln -s vim63 vim61" is really helpful.
And problem was fixed.
