m3ch4 0 Report post Posted May 1, 2005 Hey there, I've been slowly studying up on html while I earn enough credits to get a page and I've run across two curious points to do with fonts and questions about them.You can use your own fonts, but unless a visitor has the font you specify in your source code, they won't see it, but you cann't upload a font to where you upload your site page files and reference it there...does anyone know why this is?And secondly, I have yet to run across a list of fonts that are loaded by default on various operation systems. Does a list of fonts that automatically get installed with various OS' exsist somewhere? and if so, can you post links here to them?thanks Share this post Link to post Share on other sites
Dream1405241490 0 Report post Posted May 2, 2005 umm the fonts won't read because the users don't have them, therefore they can't see your font (catch-22) at least that is what I think you are asking about.To circumwent this problem, make your buttons into .gif files (or any other image file) and slice and code them. That way the users can see the cool font even if they don't have it.Lastly for the main content you can't just keep on making image files just use arial or times new roman, every computer now days have those files and they look the most professional Share this post Link to post Share on other sites
ninjamunky 0 Report post Posted May 2, 2005 Hey there, I've been slowly studying up on html while I earn enough credits to get a page and I've run across two curious points to do with fonts and questions about them. You can use your own fonts, but unless a visitor has the font you specify in your source code, they won't see it, but you cann't upload a font to where you upload your site page files and reference it there...does anyone know why this is? And secondly, I have yet to run across a list of fonts that are loaded by default on various operation systems. Does a list of fonts that automatically get installed with various OS' exsist somewhere? and if so, can you post links here to them? thanks <{POST_SNAPBACK}> 1. Just the way it is. Don't know. I guess it would be possible to have a temporary file for fonts, but there isn't LOL. So basically, the only reason you can't put a font on your server for reference is because the browser still couldn't display it. But, if you design in Flash, the font comes embeded within the file. *And if your site is really good, you could have some kind of downloader that users download that extracts the font to their fonts, or something like that. There might be a way to put the font into their directory when they hit your site, like some kind of download prompt; just an idea to play around with. 2. I think that the following links are what you're looking for; listed from what I think is best to worst http://www.microsoft.com/typography/fonts/ http://www.answers.com/search?q=list-of-fonts-in-mac-os-x http://www.fixarna.com/frontpage/windowsfonts.htm Share this post Link to post Share on other sites
m3ch4 0 Report post Posted May 2, 2005 @Dreamthanks for the suggestion, this'll probably be my main solution for things@ninjamunkyLISTS! Score! Thanks man, those were what I was looking for =Dthanks for the replys and explainations, much appreciated Share this post Link to post Share on other sites
miCRoSCoPiC^eaRthLinG 0 Report post Posted May 2, 2005 There was some way to do this... at least the technology was in its gestative stage when I'd read about it around 3-4 years ago. It's called WEFT or Web Embedded Font Technology. I haven't really kept track of it recently, so just google for WEFT and am sure you'll find loads of hits. This was supposed to set the next standards for implementing embedded fonts on sites - to overcome just what you're trying to... All the best.. Share this post Link to post Share on other sites
m3ch4 0 Report post Posted May 3, 2005 There was some way to do this... at least the technology was in its gestative stage when I'd read about it around 3-4 years ago. It's called WEFT or Web Embedded Font Technology. I haven't really kept track of it recently, so just google for WEFT and am sure you'll find loads of hits. This was supposed to set the next standards for implementing embedded fonts on sites - to overcome just what you're trying to... All the best.. <{POST_SNAPBACK}> Chased after that, and came across... http://forums.xisto.com/no_longer_exists/ http://forums.xisto.com/no_longer_exists/ http://forums.xisto.com/no_longer_exists/ ..downloaded the program and checked it out, apparantly it just adds some css coding and then creates an "eot" file that points browsers to the files to load the font characters. It's pretty slick, but it's probably something that can be coded yourself. I've never heard of an "eot" file and don't know how to create it without the program though =/ Share this post Link to post Share on other sites
iGuest 3 Report post Posted May 10, 2005 eot files are more than likely just simple text files. Just open them in a text editor and it should work.As for the font system, it is best to use the combination of the following fonts in your CSS.Arial, Helvettica, VerdanaThose three put together seem to be the pretty bogstandard text, that has literally become a design essential. Any serif-fonts are not looked upon as being eye-candy when it comes to websites. However, this rule doesn't apply to documents.For ages it has been the annoyance of many web newbies. The best way to do it is to stick to the design standards. I you are going to use non-standard fonts, then make sure they are images.--mik:P Share this post Link to post Share on other sites
m3ch4 0 Report post Posted May 10, 2005 Twitch:unfortunately eot files are not text files =/ can't open them with notepad or anythign like that.I don't really want to use any fancy fonts or anything, I just want to make sure that my site can be read the same way from any browser so I can work out table sizes and stuff. mainly that's it, just making sure things are viewable by most people.so I'll keep to arial, Helvettica and verdana, but in the reverse order I like verdana better Share this post Link to post Share on other sites
iGuest 3 Report post Posted May 11, 2005 Just remember what the public wants (unless it is a personal site).--mik Share this post Link to post Share on other sites
lesmizzie 0 Report post Posted May 17, 2005 Hey there, I've been slowly studying up on html while I earn enough credits to get a page and I've run across two curious points to do with fonts and questions about them. You can use your own fonts, but unless a visitor has the font you specify in your source code, they won't see it, but you cann't upload a font to where you upload your site page files and reference it there...does anyone know why this is? And secondly, I have yet to run across a list of fonts that are loaded by default on various operation systems. Does a list of fonts that automatically get installed with various OS' exsist somewhere? and if so, can you post links here to them? thanks <{POST_SNAPBACK}> I think the reason why you cannot upload your own fonts to the server is because of license and copyright issues. You can, however, have a link on your site that says "To best view this site, make sure you have blah blah font downloaded, and you can download it at so and so dot com." That way you can make sure that viewers will see the site the way it is supposed to look if they want to. The text will show up no matter what, but it will come out in times new roman or times. Basically these are some of the fonts that are mainly used on all OS's that you can feel safe using: Impact Verdana Times new roman Times Comic Sans MS Arial Share this post Link to post Share on other sites
Rudy1405241475 0 Report post Posted May 18, 2005 Come on lesmizzi I know you’re smarter than that. Fonts are loaded by your operating system to be used by whatever programs want to use them so copyright is not the issue.The reason why people use arial, helvettica and verdana is because they are in the set of fonts that your OS install during the installation. Times and courier are also two of them.Now if your OS did not install a standard set of fonts you would not be able to read any installation instructions, or have labels for icons etc.Now on the other had of being able to upload fonts. It would greatly increase the amount of memory usage and disk space your computer use to add a new font to the list of fonts every time someone wanted you to see how fancy their page looked. To every new site you visit you may end up with a hundred and one fonts added every two hours of surfing.Now wouldn’t that be a pain in the but? Share this post Link to post Share on other sites
saga 0 Report post Posted May 23, 2005 There are at least 4 family of fonts which is supported in almost every OS. Try visiting YourHtmlSource.com for information about fonts. Share this post Link to post Share on other sites
