Ploforia 0 Report post Posted February 3, 2005 Posted this in another section but this could apply here too.Can anyone help me with this problem I seem to be having with flash?? I know this is probably some stupid little setting somewhere I have to tweak but I can't find it. I'm trying to put a picture into flash on the canvas. I have a seperate layer for it. Nothing else is on the layer. Properties for the picture is set at 100 % quality. My publish settings are set at 100% quality for Jpegs and I've tried every setting I can find but the picture keeps displaying at a low resolution when I preview my movie. It displays fine on the design screen when I test it. But whenever I preview it - it just farts. I don't understand it. I have put tons of pictures of high rez images in flash files before and never had this problem. I had a similar problem with sound once and found like a third place to edit sound properties for the file I was working with and that did the trick - I imagine the solution is something similar but I am stuck.PLEASE HELP Share this post Link to post Share on other sites
Tobias 0 Report post Posted April 11, 2005 Do you have your browser set to view movies at a low quality? That could be your problem. Share this post Link to post Share on other sites
Neverseen 0 Report post Posted April 25, 2005 Oh I'm having EXACTLY the same problem as the person who started the topic. But I think I have almost found the solution. I think you should try to tweak the so called "bpm options"... there you can choose if it should be taken as "losless gif/png" or "jpeg" and then you have an option "allow smoothing" something like that... and so when I changed this my images turned more clear... maybe that's the problem. otherway if someone has got more logic solution, please post it here, as I'm interested in having a response too Share this post Link to post Share on other sites
ninjamunky 0 Report post Posted May 9, 2005 You might want to check out how you embedded the flash object on the webpage. Share this post Link to post Share on other sites
Maybe Skate Team 0 Report post Posted May 10, 2005 Resolution of your monitor? I had a problem once where I could see crappy picture quality because my resolution was 800 by 600 now it is 1200 by 900 and I have to problems. Note I am not a computer guru! lol Share this post Link to post Share on other sites
