suicide1405241470 0 Report post Posted September 7, 2004 take a look at this code <BODY bgcolor="#342c23"> <table width="570px" bgcolor="#83423c" align="center" height="500" cellspacing="0" cellpadding="0"> <tr> <td bgcolor="#324c23" align="center" height="54">Test 1</td> </tr> <tr> <td>Test2</td> </tr> <tr> <td>Test3</td> </tr> </table> </BODY> [code=auto:0] when the tag for the background color of the page is put in, it makes the top cell for the table appear slightly off. however when it's not in, the cell inside the table appears fine Share this post Link to post Share on other sites
iGuest 3 Report post Posted September 8, 2004 dude did u try to upload to some free webpace cause it sometimes gives error when viewing loacally and under the same deverloper kit i used to have same probb when i used to have black background but when i inserteed new table or image it showed background as Grey so some on told me that its software glitch or something if u r using software to make the page. Share this post Link to post Share on other sites
zarjay1405241470 0 Report post Posted September 10, 2004 You should use CSS to change your background color. In the header of your webpage, all you need is this code: <style type="text/css">body {background:#342c23}</style> Share this post Link to post Share on other sites
SinisterMinisterX 0 Report post Posted September 12, 2004 Suicide, I tried your code and I don't see what's wrong with it. It looked fine to me. (Aside from some strange color choices, but that's just my opinion. ) Could you be more specific about how the top cell looks "off"?Perhaps it's a browser-related issue. I looked at your code with IE 6, just for the record. Share this post Link to post Share on other sites
kokushta 0 Report post Posted September 12, 2004 It looks fine to me, IE 6.0 and NS 7.02maybe it's a browser related bug. Share this post Link to post Share on other sites
japanick 0 Report post Posted September 13, 2004 Code looks bug free, and works fine on IE 6 and Mozilla firefox. Please tell us what exactly is going wrong w/ your page, because it should work both with the bgcolor tag in the body, and without.(And I think the colors are pretty cool ) Share this post Link to post Share on other sites
nhansroul 0 Report post Posted September 13, 2004 Hey!I tried it with IE 6 and it perfectly works!! It also really works on Free..What's your explorer version??? Share this post Link to post Share on other sites
Kovi 0 Report post Posted September 14, 2004 Is it that the top table seems very slightly shifted to the right, and maybe back? If that's what you're talking about, then it's a simple visual effect of the colors you've chosen. I'm not entirely sure why it happens, but a few minutes searching Google should turn up the reason. If you also want a more apparent example of this effect, try placing a block of blue right next to a block of red against a black background. Share this post Link to post Share on other sites
