noclue92 0 Report post Posted May 24, 2011 (edited) I basically want to learn the code or whatever to make a website,and how to make a server myself to put it in, and the tools i need, and anything else. It is always been something i wanted to learn, but so far i have had no luck. What i need most is a teacher. I need to know were to start. Im just taking a chance posting this on this site and hope someone can help . Any direction would be nice. Edited April 17, 2012 by moderator (see edit history) Share this post Link to post Share on other sites
Darkyo13 0 Report post Posted May 24, 2011 also if any1 would want to help him don't do it trought PM post it here i'm curious too and i want to learn new things Share this post Link to post Share on other sites
rob86 2 Report post Posted May 24, 2011 I found http://www.w3schools.com/ to be very helpful. There are lessons on the left. I learned a lot from this site, and I think HTML and CSS should be the best place to start. As for getting a place to try your code, you can either post here and earn money to buy a domain like http://forums.xisto.com/no_longer_exists/ or download something that can be run locally on your computer. I think running a local server is the best way to start out as long as you don't expect many (or any) visitors to your practice site. A good way to try it out is to download http://www.wampserver.com/en/ which installs everything you need easily. Share this post Link to post Share on other sites
Xamire 0 Report post Posted June 7, 2011 Between servers, coding and the likes, you will end up running for the hills, due to the complexity. Coding itself requires a substantial amount of time. The biggest, and best advice I can give you, is to start out with a CMS (content management system) and play around with that first. They're pretty easy to install, and play around with, but can take a bit to master. Once you get that down, then you can start messing with files, and how to change colors on specific parts, etc. This will give you some basic understanding and knowledge on how all this works, instead of simply throwing yourself into the fray. Millions and millions are donated toward cms's and they are designed, and programmed by many, many programmers and designers. Even if you taught yourself all the odds and ends, it would still take around 10 years to make something like this yourself. Most cms are free of charge, and even a majority of their extensions (forums, yahoo ask, etc) are free of charge. I would say, that you should start out a bit smaller, with Wordpress. From there, you can go to either Joomla (my favorite), or try out Drupal, or some other CMS. Wordpress is the easiest of them all, I believe. Wordpress.org Joomla.org Drupal.org There are many other options on the market, but these three have the most funding (several millions per year), have the most programmers, and some of the best extensions, and designs on the market. They're also 100% free. Download the package, unzip the package, and use an FTP program to move it over to your server (I use filezilla). Then you need to create a database in cpanel, and use the information it gives you after creating one, in the web setup. Yes you set these up by simply going to your website. It's rather easy, and quite fun to play around with these systems. But, I'm telling you now, that if you just dive right into coding, and styling, then you will want to scream and run away from this because it's far too much to grasp. CSS alone is a ton to grasp, not to mention when you start throwing in mos (transparency), and other effects that are higher css grades. Share this post Link to post Share on other sites
hunjun 0 Report post Posted September 5, 2011 i love the design and color of the main page but i think it doesn't fit with the forum color. so you can just change the background color of the main page and make it exactly the same color of the forum and i think it will be great since the orange and yellow are fit with the dark blue either. Share this post Link to post Share on other sites
michelqueyrane 0 Report post Posted October 4, 2011 My opinion is quite different from hunjun. I liked the background color of the site and its perfect according to the forum. Share this post Link to post Share on other sites
