Xisto Corporation
Jonnyabc
Xml Load() Problem Validating the length of array.
Can't seem to figure out this small problem, so I thought I'd send it out to kS to see what I'm not thinking of.
Here are the steps I have taken thus far:
Created an RSS feed
Designed a multipurpose feed reader that will pull data from the RSS feed
Using load() and getElementsByTagName("item") to pull in the data
Part of the reader's parameters are the number of rows to display
There's only one problem...when there are no results to display, it comes up with an error. The simple solution should be to either determine if the first value for the array exists or is blank. Either way, I can't seem to get the array correct no matter how much I try. I've attempted count() and sizeof(), but both return "1", and the error only arises after I try to read from the array using the getElementsByTagName(), so both are a "big help".
Maybe it's late...maybe I'm not thinking straight. Whatever the case, I needed to get connected with you guys again since the shoutbox (or its replacement) is not back online yet.
I'm pasting the code and error below:
2	$rssFile = new DOMDocument();3	$rssFile->load("./rss/?id=" . $feedID);45	//get and output "<item>" elements6	$item=$rssFile->getElementsByTagName("item");7	$y=0;8	if($feedCount>count($item)+1) $feedCount = count($item)+1;9	if(isset($item->item(0)->getElementsByTagName('title')->item(0)->childNodes->item(0)->nodeValue))10		{11		for ($i=$feedStart-1; $i<=$feedCount-1; $i++)12			{15			$item_title=$item->item($i)->getElementsByTagName('title')->item(0)->childNodes->item(0)->nodeValue;16			$item_link=$item->item($i)->getElementsByTagName('link')->item(0)->childNodes->item(0)->nodeValue;17			$item_desc=$item->item($i)->getElementsByTagName('description')->item(0)->childNodes->item(0)->nodeValue;
Fatal error: Cannot use object of type DOMNodeList as array in C:\wamp\www\jl-ectronics\resources\php\feedreader01.php  on line 9
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
