Someone
Borland C++ Builder Problems I have tried simple examples....
I have tried "programs" like hello world but I get erro with getchar or if I use with namespace! I don0t know what to do, I can't do anything ! Should I use visual c++ or other c++ I get same problems with dev c++, please help I must know why is that :P
Try the latest release of Dev-C++, I had the same filestream problem...also post some example code, thanks.
the problem is that my c++ builder compiler was to old, form 1997 :Pall exmples works in dev c++ :D But now I have questionHot should I link some file I mean if someone click on about then browser open a txt file for example and how should I define new page, if I don't use tabs because I don't know how, this mean that then browser will open another exe like in IEthanks
42677[/snapback]
some lower compilers don't support namespace
if you get an error with getchar,
add this at top of the code:
#include <stdio.h>;
thanks
Do you mean how you set a new page in Dev-C++? Ctrl+N
For linking, create a project file (File->New->Project) type in settings,
press enter. Then, go to Project->Project Options, or Alt+P. Go to parameters
and enter them in linker. Or... just create a makefile.
#include <stdio.h>;
43133[/snapback]
Yes compiler is to old :P I downloaded a new one form c++ builder 6 but I don't know how to intergrate it in this c++builder !?
43597[/snapback]
The latest can be quite compatible the oldest one.
Make sure that you have included header file #include<stdio.h>. And this header file should be at the top of your program. IF you have included the header file at the proper place then you check for directories settings.
